Did a warranty inspection today on a upscale townhome that is a rental property. One item I noticed was that the step down to the garage from the interior as you went out the door was 10". I know the normal rise of a step is around 8". This is a concrete slab step.
This difference was noticable by feel to me as I stepped out. Is there a max allowable? How would you call this out? I see it as at least a trip hazard. Repair options seem pretty limited. Thanks Professional Inspector Level I Infrared www.AbsoluteInspections.net www.homeinspectorsplanotx.com www.homeinspectorsmckinney.com Absolute Inspections, LLC 972-463-0887 Last edited by kweiss; 9/26/06 at 6:18 PM.. |
Roy Cooke |
lewens is a non-member guest and is in no way affiliated with InterNACHI or its members.
Maximum allowable is 7 3/4". Roy is right a 5" step will fix the problem.
I noted that the step was too high and a trip hazard. I will allow the builder to come up with the solution if the client decides they want it fixed.
Thanks for the answers. Professional Inspector Level I Infrared www.AbsoluteInspections.net www.homeinspectorsplanotx.com www.homeinspectorsmckinney.com Absolute Inspections, LLC 972-463-0887 |
| Garage step | kmilton | General Inspection Discussion | 5 | 7/27/07 5:02 PM |
| Step up from garage to house | dmacy | Exterior Inspections | 6 | 10/30/06 6:26 PM |
| step down to garage? | rjennings | Interior Inspections | 30 | 8/3/06 11:34 AM |
| Height Requirement for Line from House to Garage. | mlong | Electrical Inspections | 9 | 4/7/06 9:33 AM |
