Old 11/26/07, 5:26 PM
pwigle pwigle is offline
Default stepped crack
This picture shows brickwork above the side entry door on a 50+ year old bungalow. No other signs of cracks on this wall. Do you think the crack was caused by installation of octagon box some years ago (I think quality of masonry work suggests box was added after construction(?)). Or should I suspect some other cause? The crack is not visible in the horizontal portion of the mortar joint.
Old 11/26/07, 5:46 PM
Ian Gills Ian Gills is offline
Please Note: Ian Gills is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: stepped crack
To my untrained eye, it appears the box was fitted and moisture has penetrated. Successive freezing and thawing has generated the crack.
Old 11/26/07, 6:40 PM
Steve Taylor Steve Taylor is offline
It could also be a failed lintel.
Old 11/26/07, 6:58 PM
jking2 jking2 is offline
I would look for foundation cracks. It may be that one corner of the foundation has settled, creating tension on upper portions of the wall, and the wall cracked and spread at its weakest point: the narrow portion of brick above the door.
Jim King
Old 11/26/07, 9:29 PM
Perhaps it is just the picture, but it looks like there is a very slight sag at the center of the window frame, just below the crack. If that is the case, I would guess lintel movement or failure. If there are no other indications anywhere in the area of structural failure, or bowed walls, etc., personally I would recommend pointing/repair and monitoring.
Abraham Lincoln
Old 11/26/07, 10:15 PM
afrost afrost is offline
Please Note: afrost is a non-member guest and is in no way affiliated with InterNACHI or its members.
settlement caused by ___?
may or may not increase. will allow weather infiltration and further damage if not repaired by a qualified contractor.
Old 11/26/07, 10:50 PM
mthomas2 mthomas2 is offline
Peter,
Do you have a wide shot of that side of the building?
Old 11/26/07, 11:01 PM
The best I have is a photo of the rear quarter. The crack is over the door in this picture. Note that there is also a thin crack, about 2' long vertically in the foundation at the back (circled in red). Thanks.
Old 11/26/07, 11:04 PM
rwand1 rwand1 is offline
The step crack above the door could be a relief crack. Given its location and only several courses of brick above I don't believe its anything to worry about.
Old 11/26/07, 11:07 PM
The two cracks are not related.
Old 11/27/07, 10:24 PM
Peter
Not to familiar with your area.
Is the foundation CMU, Poured Concrete, Triple Brick ?
Any signs of movement on the inside, either under or adjacent to the areas of concern? Ex: moisture penetration, settlement at footings or exterior steps?
What are those (assumed) white PVC pipes to the left of the door in question?
Be interested in what you end up determining/confirming.
Old 11/27/07, 11:02 PM
Hi Greg, The foundation is poured concrete. No cracks on the finished surface inside but the crack does continue under the door (at the right side). I didn't notice this until this morning - it is below the sill, and then disappears behind the concrete porch.
The pipes (galvanized steel?) lead to an oil tank in the basement.
I think settlement is the problem - only a guess. I pointed out the cracks to the prospective buyer. He is not concerned since the cracks are thin and without lateral displacement - and better than most other houses of similar age which he has looked at. Thanks for your response.
Old 11/27/07, 11:53 PM
wsiegel wsiegel is offline
One of you said failed lentil. One of you thinks it is a settlement problem. One of you says it is no problem. Think about what we have here. One problem with three different diagnosis. What happens if one of you is right and two of you are wrong. I personally think Andrew came the closest with his response. Just food for though.
Old 11/28/07, 8:10 AM
So William, how do you know Andrew is right?
Old 11/28/07, 10:50 AM
Because he called out for repair by a qualified contractor rather than trying to determine the cause of the problem.
Crack Control Joints aroncone Canadian Inspectors 3 11/20/07 8:49 AM
Crack in tile floor? pcloninger Structural Inspections 10 10/9/07 12:15 PM
Diagnsing a V crack dmacy Structural Inspections 16 4/20/07 12:14 PM
Slab Crack rchorey Structural Inspections 11 7/9/06 2:54 PM
Crack in the wall jburk2 Structural Inspections 22 1/19/06 7:29 PM
