Old 12/22/09, 8:51 AM
Jeffrey R. Jonas's Avatar
Default Strong-DriveŽ SD Screw for Structural Connectors
http://www.strongtie.com/sdscrews/in...wsletter=Dec09
Simpson Strong-Tie introduces the SD Strong-DriveŽ load-rated screw for use with our structural connectors. Designed to replace nails in certain products, the SD9 and SD10 have been designed, tested and approved for use in many popular Simpson Strong-TieŽ products. In certain applications screws are easier and more convenient to install than nails, and the single-fastener load values achieved by the SD screws exceed those of typical 10d common or 16d common nails. In addition, the galvanized coating makes the SD screw ideal for interior and most exterior conditions.
The SD screw features an optimized shank which is specifically designed to match the fastener holes in Simpson Strong-Tie connectors. The hex head virtually eliminates cam-out and helps avoid stripping of the head. The sharp point of the screw enables fast starts, and the serrated threads reduce torque for improved drivability.
SD Screws for Use with Simpson Strong-Tie Connectors:
  • Tested and approved for use in many popular Simpson Strong-Tie connectors for interior and most exterior applications
  • The single-fastener load capacity of the SD9 exceeds the capacity of a 10d common nail, while the single-fastener load capacity of the SD10 exceeds that of the 16d common nail
  • Ideal for use in tight spaces where using a hammer is inconvenient
  • Optimized heat-treating for ductility, strength and reduced hydrogen embrittlement concerns
  • Mechanically-galvanized coating meets ASTM B695 Class 55, is recommended for use with certain preservative-treated woods and is compliant with the 2006 International Residential CodeŽ (R319.3) and 2009 International Residential Code (R317.3.1)
Learn more about the Strong-Drive SD Screw for Structural Connectors
Visit the Strong-Drive SD Screw product page to learn all about the SD Screws and the connectors they can be used with.</SPAN>
Find an InterNACHI certified Delaware Home Inspector (and anywhere else in North America)
Old 12/22/09, 10:12 AM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Default Re: Strong-DriveŽ SD Screw for Structural Connectors
Our local AHJ allow Ledgerlok fasteners to attach to the deck ledger board to the house.
Mid America Property Inspections, Inc.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
KS-Radon Cert.# KS-MS-0035
KS-Termite Cert. # 18933
M0-Termite Cert. # N 5033
Old 12/23/09, 12:01 AM
Brian K. Smith's Avatar
Brian K. Smith Brian K. Smith is offline
Send a message via AIM to bsmith2
and they work good to....ive buit many patios and used them.
Old 12/23/09, 2:43 PM
Yes, they do work. Most contractors drive them into the wood to far with the nut driver.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
Old 12/23/09, 5:04 PM
That is why I prefer the GRK structural screws.
As expensive as the Simpson's SS screws are, I would not think you would see much used other than selected hangers that require face screwing and not used on toenailing purposes.
Gas Connectors Recalled ldapkus General Inspection Discussion 1 3/4/08 8:32 PM
Subpanel Bonding Screw away Electrical Inspections 24 1/9/08 2:46 PM
Steel post question sspradling Structural Inspections 42 3/2/07 8:59 PM
Per capita market strength of NACHI by State/Province. gromicko Miscellaneous Discussion for Inspectors 3 1/8/07 2:53 AM
