Brand new three story town home today. It is the builders model unit. On the third floor there are two doors out of square (settlement cracks at the top of both the doors). The floors to both stall showers have sunk about an eight of an inch, large enough for me to stick a thin metal ruler under an poke back to the pan. The window sills have lost their seal in the corners. This is only on the third floor. The other two floors show no problems.
Just wondering how some of you would write this up. Something is wrong here, but obviously it cant be seen because i am looking at a finished product. FYI - there is no indication of any problem on the exterior of the unit. |
| Find an InterNACHI certified Wisconsin Home Inspector (and anywhere else in North America) |
Ask the builder to explain the defects on this new building and fix them. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Not a matter of whether it is under warranty or not. My client has to make a decision on to buy or not to buy based on this issue, knowing that it could lead to future problems.
I am leaning toward suggesting that my client get a separate structural inspection, at the builders expense, of course. |
Observed signs of movement at a couple of locations and signs of settlement to create cracks above doors.
Recommend a licensed qualified builder to evaluate and repair. William, since this is the third floor and I am assuming it is all wood frame, it is conceivable that some of those walls are bearing walls and possibly picking up the weight of the roof also. If some of those walls were framed on the second floor of the house and run parallel to the floor framing, this could cause what you are explaining. Also some of the walls could be offset to far from bearing walls below. There are a lot of variables to cause this in a new structure. Pictures would help. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Here are some pictures. FYI- concrete block
William, the block walls don't affect what I said earlier.
The tile floor gap is minor shrinkage and can be sealed with a silicone to match the grout. This is normal on a wood floor dependant on where it was framed in relation to the span of the floor framing below it. It could also have been caused by high moisture content in the wood and now it is shrinking. Like Larry above mention, to make a long story short. Report what you observed and recommend that it be repaired. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Marcel Gratton, NACHI04011210, CMI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
Mark S. Tyson M Tyson construction LLC Tyson Home Inspections Certified General Contractor #1516843 Florida Licensed Home Inspector #1824 Member N.A.C.H.I. IAC2 certified Member Florida Building Officials Association http://www.TysonHomeInspections.com |
did you not read the whole post? Not only are there cracks, but two of the doors will not close. And what about the separation of the shower floors. It also says that this is the model unit, which means the AC has been running the whole time. I do not know how you can make such remarks with the information given. |
I have had 2 inspections in the last week that needed follow up by a structural engineer.
The first house was built in 2005. There was a crack in the garage floor. It was about 1/4 to 3/8 wide, with about a 1/4 inch of differential settlement. Inside the home all of the rooms on that side had cracked drop angles, cracks around window and door headers and the baseboards had separated at least a 1/4 inch. I recommended they obtain the opinion of a structural engineer. The buyer decided to look at other houses after reading the engineer report. My first inspection today is for his next house. The second house was built in 1959. The garage floor had a crack of 3/4 inch about 6 ft away from the exterior block wall. There was about 3/4 inch differential. The garage had a work area that has a step up. I could see that the floor had sunk at least a half inch towards the exterior wall. I recommended that they obtain the opinion of a structural engineer. I think you are taking on a lot of risk if you don't recommend that the client obtain an opinion from the expert when there is clear evidence that something is happening. Bill I would have no problem with telling the client that there is evidence that settlement is occurring and given the number of red flags I would recommend that you obtain the opinion of an expert. Greg Bell Titusville, Fl 02111507 Serving Central Florida
| Preventing Moisture related Problems | mcyr | Ancillary Inspection Services & Additional Topics | 1 | 12/19/07 9:30 AM |
| Tidbits from the ASHI Message Board | jbushart | Miscellaneous Discussion for Inspectors | 124 | 4/27/07 12:05 PM |
| Light Bulbs- All Ya Wanna Know | pabernathy | Electrical Inspections | 9 | 4/18/07 8:22 PM |
| CBC - Province called on to force home-sellers to disclose property's problems | rwand1 | Canadian Inspectors | 2 | 4/5/06 9:40 PM |
