Ramir Santos is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hi Everyone,
I am in the process of replacing my carpet and found out a huge crack on my concrete floor. From what I know, it is a pure concrete 4" to 6" above the ground level. Could someone confirm by looking at the pictures whether I have a structure damage rather than a normal concrete crack? https://picasaweb.google.com/1131386...39339675051122 https://picasaweb.google.com/1131386...39341695492770 https://picasaweb.google.com/1131386...39337565652370 I appreciate all your help on this! |
| Need a home inspection in Iowa? Check out InterNACHI's listing of Iowa certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Is there any horizontal displacement? Lacking control joint, concrete cracks.....Google Concrete Cracks for a lot of information. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
However, the cracks look like pretty common slab-cracks, which are not generally a structural "issue." Check the exposed footings and stem walls near the slab edge. If the cracks continue through these structural components, you'll need to get someone out there to evaluate the situation. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Hire a professional Nachi inspector in your area......they can look at it more closely and advise you.
Jeff |
Thank you all for all your responses.
There is a slight misalignment on the floor. I am just scared that considering that this is a pure concrete, it would produce a wide and long crack. This is just a 6 year old newly constructed townhomes. Can someone recommend a nachi member close to Bayonne, NJ? |
Thank you all for your reply!
Dale: there is a slight disjoint only at a small portion close to the start/end of the crack. Other than that, it is a concrete crack through out. Jeff P: the crack is in the middle of the floor and no signs that the stem and wall arempacted. Although I dont have 100% visibility on it. Jeff H: Thanks for the reply! |
All concrete cracks ... but different cracks mean different things. Some slab cracking can be the first signs of a problem, even if there are no stem wall cracks. Some cracking is simply the result of a poor slab base or shrinkage. Figuring out what the cracking means just cant be done over the internet, even with a buch of pictures.
An on-site evaluation should be done by an inspector who is a licensed engineer (PE) in order to get a more definitive answer. State laws do not allow inspectors who are not PE's to do a structural evaluation. JMO & 2-Nickels ... Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
It is impossible to see from those photos the degree of deficiency.
Any foundation crack is suspect and must be monitored. The Inspector must have engineering and or structural concrete field experience. A Licensed Certified concrete repair and evaluation company would be my answer. Try this number. http://www.valuedry.com/basementwate...newjersey.html I pray it is shrinkage cracking but it still must be investigate. The report by the company engineer will be about 300-500 dollars. I would get 2 myself. That price is what concrete structural evaluations are in Montreal Quebec. Please keep us posted. We would love to follow the story. Thank you. ROBERT YOUNG. PS: Good luck. montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 |
| Concrete for Exterior and Structural Walls. Please proof this new inspection article. | gromicko | Structural Inspections | 0 | 9/8/10 2:51 PM |
| New article: Concrete for Exterior and Structural Walls | inxil | InterNACHI & RealMatcher Blogs | 0 | 9/8/10 2:40 PM |
| Shooting to begin on comprehensive new roofing courses | kshepard | Inspection Education & Training | 4 | 11/7/09 2:59 PM |
| Hail Damage | jhaynes | Exterior Inspections | 12 | 7/23/09 5:23 PM |
| Snow Roof Damage Inspectors in Coeur d’Alene, ID 83815 | rspriggs | Ancillary Inspection Services & Additional Topics | 0 | 1/9/09 3:23 AM |
