This is an automatic recommendation for a structural engineer. They cut the beam, which carries the second floor weight, to fit the garage door opener track. This got me wondering, can you ever cut a steel beam?
Michael Merino Merino's Home Inspection & Education Inc. "Not just an Inspection, an Education"SM Phone/Fax 708~535~6057
| Find an InterNACHI certified South Carolina Home Inspector (and anywhere else in North America) |
Yes you can, but without more information, it's difficult to tell whether this will be a problem.
What else do you need to know, I will provide it. 2 car garage with bedrooms above, post on each end of beam, more than 50% of that beam is cut. No sag in the beam, post bolts are loose, finished ceiling above the beam.
If there's no deflection, I wouldn't be too concerned about it. The top and bottom flanges are still intact, there's not enough of the web missing to worry me, and it's not over a support.
As a former Ironworker, I may have a tendency to "minimize" the effect of this type of cut, simply because I've seen it so often. As a home inspector, it would be within reason to seek a second opinion, but I doubt an engineer would disapprove. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Thanks Jeff, I will most likely recommend that and engineer take a look, the client was really concerned about it.
Not a problem at all in my book, but that is thinking about it under a different hat and book.
At least it could have been done in a more professional way where it would not raise as many eyebrowse. Typically, a round hole would have been preffered by the Engineer and away from the center span of the beam. So your call to have an Engineer look at it is in a true prudent way of handling this. Nice find, not something we see here everyday. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Thanks Marcel.
I was looking online for specifications on steel girder notching and I did not locate anything. I went through my illustrations and found a picture from Carson & Dunlop.
It states the girder should not be notched. I wonder if they could of done something different with the garage door opener instead of cutting a large hole in a structural component. I understand the columns and load are not located at the hole in the girder but over time would there not be a concern of splitting/sagging. I would also call out for further evaluation. |
Exactly, Mr. Larson!!
Good posts Mike & Mike. (Sounds like an ESPN sports show)
Never new or have seen this type of opener. This may be a good link to forward to the concerned client. |
That jack shaft opener still uses a torsion spring.
1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
That is correct, and Wayne Dalton has also come out with this newer model that installs in the center of the door.
Pretty neat model.
Marcel
Very Nice!! Great information for future inspections. I have seen at least 3 main girders cut for GDO's. |
That's for dimensional lumber David.
Steel I-beams are similar to an engineered joist. Cuts and holes are allowed in specific locations within the web. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
| Site-built trusses- always recommend a structural engineer? | kshepard | Structural Inspections | 33 | 2/12/11 3:26 PM |
| Where do I put the Aquarium? | mcyr | Structural Inspections | 3 | 11/6/07 3:05 PM |
| Illinios structural engineer | jkrumm | General Inspection Discussion | 1 | 4/19/07 12:21 AM |
