Old 9/8/08, 5:23 PM
Erol Kartal Erol Kartal is offline
Please Note: Erol Kartal is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Structural Support Damage
Several 10" X 20' steel columns damaged by forklifts. Does the one on the left also need bracing? The tops are bolted securely at beams.
structural-support-damage-p1020834.jpg   structural-support-damage-p1020833.jpg   structural-support-damage-p1020831.jpg   structural-support-damage-p1020824.jpg   structural-support-damage-p1020826.jpg
Old 9/8/08, 5:28 PM
Dale Duffy's Avatar
Default Re: Structural Support Damage
Hi Erol,
I would simply write which columns have physical damage in the report and say if they want to have them evaluated by a structural engineer here is his phone number.
But if I was buying the building, personally I would not give much thought to the bearing strength they have (by looking at your pictures) anyway.
Old 9/8/08, 5:33 PM
Hi Buddy.
Do you mean they're so bad (from what you can see in the pics) that it's a no brainer, or that damaged columns like these tend to hold their own weight.
Old 9/8/08, 6:15 PM
Dale Duffy's Avatar
Hi Buddy.
No, personally I don't think the damage poses any imminent structural failure, but I would recommend installing-building some sort of balusters or protection around the columns so they don't get hit-clipped by something in the future...yada yada...
I would write it is my personal opinion, not being an engineer, the columns being obviously damaged probably do not pose any imminent structural failure in the near future, but if damage continues you will be risking the possibility. An engineer can design a repair method for you and also design a protection system so future damage will not occur, therefore I highly recommend you contact an engineer to look at the columns.
And if they would like my engineer to look at the columns, here is his phone number, he charges about 200 bucks which is rather inexpensive.
Old 9/8/08, 6:40 PM
Jeffrey R. Pope's Avatar
I agree. Ugly, but not likely to be significant as these interior columns are in compression more so than anything else. The webs appear to be undamaged. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 9/8/08, 7:37 PM
James F. McKee's Avatar
are those columns in the living room Erol????...Might want to recommend posts in front of columns to reduce future impact damage....jmo....jim
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 9/8/08, 9:40 PM
The bombing of the Twin Tower Columns were damaged more than than and the building stayed up.
Need of repairs and protection from physical abuse and further damage that could possibly impair the capacities of the structural column.
Marcel
Old 9/9/08, 12:51 AM
Mark Jones Mark Jones is offline
I repaired collums like those about 15 years ago. Heated 'em up with a torch, pounded 'em straight with a BFH and welded up the splits. I don't know if there was a engineeer involved but the owner of the company kept tearing his suit pants whenever he went into the factory. He did tell me a few people got some nasty cuts too. So I'd recommend they be repaired.
Mark Jones
Allmark Home Inspection Services Inc.
Serving all of Northern Illinois, Vernon Hills, Libertyville, Gurnee, Fox Lake, Round Lake
Phone: 847 651 2053
E-Mail: AllmarkInspect@aol.com
www.AllmarkHomeInspection.com
Old 9/9/08, 12:57 AM
mreusch mreusch is offline
Send a message via Yahoo to mreusch
Seems to me some lessons in forklift operation may be needed, and probably a wise investment as well. If they can't see a column one can only imagine what there stock or inventory may look like. LOL
Where do I put the Aquarium? mcyr Structural Inspections 3 11/6/07 4:05 PM
Chicago area structural damage Anita Casey Structural Inspections 2 7/6/07 9:43 AM
Steel post question sspradling Structural Inspections 42 3/2/07 9:59 PM
