I have a question because I personally have never ran across this before. In the garage the exterior walls were build then covered with a styrofoam board (not the standard rigid foam board like DOW etc...). There are several areas where it is damaged and the vinyl siding is exposed. It just falls apart when you touch it. (See Pictures)
What is your opinion of this? Last edited by tlower; 5/4/10 at 5:24 PM.. |
| Need a home inspection in Arkansas? Check out InterNACHI's listing of Arkansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I would say if its deteriorating then it will be a matter of time until the siding becomes loose also. It could cause siding issues if it hasent already. What a fun repair that will be, especialy if its the whole house. It could be from the heat. I would think the application should be sufficent, but I can't tell you why its rotting.
Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
Your right, some of the siding is loose. Probably from objects falling into it from inside the garage. I would hate to see if someone tried to prop up their bicycle on this wall, it would fall right through
They neglected to finish the inside walls and protect the foam!! |
Tim,
I have built a lot of houses but have never seen white styrofoam used for sub sheathing. It looks like the type of styrofoam used in basement remodels which has a poor bonding trait. In other words it falls apart when touched. Just a guess. |
prichardson is a non-member guest and is in no way affiliated with InterNACHI or its members.
This is the standard method for manufactured homes. They only use sheathing on the corners, and styrofoam everywhere else. The busted foam is probably from interior damage. It is ok for a garage if you add insulation to the cavity and an interior wall finish of some kind.
You can break into these types of homes with a pocket knife!
In the mid-to-late 1980's, I was hired by a housing co-op to inspect a couple of duplexes they were were having built using this style of energy efficient construction. This was in a fairly "rough" part of town........never heard of them being broken into with a "sharp utility knife". |
| Kansas Board Approves NAHI and ASHI Tests - Denies NACHI Test | jbushart | Legislation, Licensing & Legal Issues for Inspectors | 29 | 2/22/09 5:15 PM |
| Basement vapor barrier | jfrederick | Interior Inspections | 10 | 2/14/09 4:54 PM |
| Free mailing labels and postage for anyone wanting to write Kansas legislators. | gromicko | Legislation, Licensing & Legal Issues for Inspectors | 739 | 1/22/09 10:18 PM |
| Yippee!!! Kansas AG says association membership requirment unconstitutional! | gromicko | Legislation, Licensing & Legal Issues for Inspectors | 41 | 11/30/08 12:34 PM |
| Question about exposed styrofoam insulation. | mlong | Exterior Inspections | 9 | 12/21/07 8:33 AM |
