Old 10/13/09, 12:49 AM
Joe Funderburk, CMI's Avatar
Default Sub-floor structure and insulation covered
Why would someone install plywood in some areas and some sort of thermal reflective barrier in other areas of the sub-floor of a crawl space? There were some openings from which I could confirm the presence of fiberglass batt insulation. This is totally unorthodox in this area of the country and I don't like it because it conceals the structure from inspection for possible defects. Other than that, is there a downside to having it installed? Would you recommend its removal?
sub-floor-structure-and-insulation-covered-101209-176.jpg sub-floor-structure-and-insulation-covered-101209-177.jpg
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Find an InterNACHI certified New Hampshire Home Inspector (and anywhere else in North America)
Old 10/13/09, 9:19 PM
Default Re: Sub-floor structure and insulation covered
Here Joe if it helps.
http://www.we-intl.com/pdf/crawlspace.pdf
http://www.fifoil.com/Builders/Appli...ionInfo/?ID=10
http://www.buyfoilinsulation.com/cra...ation-c-4.html
Old 10/13/09, 11:34 PM
So, Marcel, you're fine with it?
Theodore Roosevelt
Joe Funderburk, CMI
Old 10/13/09, 11:45 PM
Dale Duffy's Avatar
Attachment 32578 Attachment 32579
Hi Joe,
Looks like a waste of the "Product" if in fact it works like they claim....I see it once in a while here in AZ (attics)....supposed to "Reflect Heat"....my IR Thermometer seems to beg to differ with the product data information---
Old 10/14/09, 1:07 AM
Paul Pendley Paul Pendley is offline
Why is the one joist painted gray? That would suggest that it was fire damaged. Unless of course my eyes are playing tricks on me again.
Paul Pendley
Premier Property Inspections
866-458-8516
Old 10/14/09, 11:02 AM
I didn't actually inspect this house. I was there < 5 minutes looking at it generally for a past client. I didn't notice the gray beam.
Theodore Roosevelt
Joe Funderburk, CMI
Old 10/14/09, 2:12 PM
Bob Elliott's Avatar
I do not think lack of viewing pleasure is enough to recommend removal any more than I would suggest taking down all the drywall in a finished basement.
Old 10/14/09, 7:10 PM
Joe, I don't really see anything wrong with it, but sure there might be pros and cons in Building science in doing it that way.
It could depend on the surrounding conditions also to establish if it could be a problem or not.
I have seen it occaissionally up here. It is a vapor retarder as well as an insulator.
Poly being applied to Basement walls dvalley Interior Inspections 40 11/24/09 11:49 PM
"A Bridge Too Far" mcyr Exterior Inspections 7 12/18/08 6:38 PM
Options in selecting materials for basement construction wdevries Canadian Inspectors 2 8/4/08 2:30 PM
New Old Insulation rcooke Canadian Inspectors 1 12/13/06 6:25 PM
