Two questions on type structure I do not see often.
Home is 1998 build and does not look modified meaning this is most likely part of the original design. First question is besides earth to wood contact would you consider this post as needing bracing and second question is what do you call the part of the home it supports ? All comments welcome. |
| Need a home inspection in Kentucky? Check out InterNACHI's listing of Kentucky certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
picture?
Sorry just caught that as I am working on the report.LOL.(darn you were fast)
Ignore the curvature in the one as it is off a fisheye effect from a video shot. Post is at left side corner in last picture. [ATTACH][ATTACH][ATTACH] [/ATTACH][/ATTACH][/ATTACH]
"Cantilever"?
Minimum 6 x 6,? Is it stucco clad? If so, its too close to grade. Is it in a driveway and subject to mechanical damage? Can you confirm if there was a proper concrete footing below the frost line? Was is secured both top and bottom? Rick Strand, CPI CAHPI Associate Strand Home Inspections Inc. Calgary, Alberta, Canada Serving Calgary, Okotoks, Airdrie, Chestermere and Cochrane Alberta
well from Ohio I would say if the cantilever for the bedroom bump out were done properly the post would not be necessary, but it would be impossible to tell that without removing sub floor or drywall.The one picture seems to show a bow in the post which could indicate compression and perhaps an improperly framed cantilever...
I said ignore the bow as it is due to fisheye effect from that being a video shot however should I mention it being in need of bracing ?
Just comment on earth wood contact and leave it be? The porch was built using nails for the ledger and improper support so my suspicion level is high. |
How would I Observe proper attachment at top ..lol? |
If there were no bow Bob I would just mention the post earth contact and move on...
Does the fact it is possibly cantilevered change that? Maybe I am over thinking but sure would hate to miss an obvious. |
Same principle applies as to a deck supported. If it is over 12' it should be a 6x6 post for support. I think someone ran this for convenience of the gutter system and not an actual support for the cantilevered bedroom. If it is a support this is foolish, a 45-degree support to the wall like you would see with a overhanging front entrance would have been a better Idea.
THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
So if your report would you comment on anything? Gosh glad my afternoon cancelled for today.(yet another blunder) Bank did not deteriorated-winterize. |
An HI is a non-member guest and is in no way affiliated with InterNACHI or its members.
It looks like a 6 x 6 PTL Timber
How is the Footing? Concern is the downspout piping adjacent. How is the sub grade drain installed if a footing is present? Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
Likewise, a 45 degree support would most likely needed to be engineered. |
It goes underground to edge of a giant reservoir behind my back while shooting.
| First 12 members to post win Safety Practices for the Home Inspector book. | gromicko | General Inspection Discussion | 47 | 12/23/09 10:23 AM |
| 47 piece DeWALT drill bit set. First 12 members to post win. | gromicko | Legislation, Licensing & Legal Issues for Inspectors | 53 | 12/21/09 6:15 PM |
| Another way to support a house | dvalley | Exterior Inspections | 3 | 10/30/09 3:45 PM |
| Post Turtle | ldapkus | Miscellaneous Discussion for Inspectors | 8 | 10/30/08 1:36 PM |
