This is new construction home in Texas hill country. Outer foundation wall is masonry block with pressure treated posts underneath on 8' centers. The posts are set into soil with concrete.
First pic shows support post that was sort and extended. Second pic - Should the posts be cross-braced / tied together to prevent racking? The floor joists sit on top of posts; but the posts are not connected to each other. Where can I find specifications for this type foundation? Thanks, Linda |
If it were a basement, I would not expect to see any cross bracing on columns, but in the case of a basement the beam(s) can't move due to the foundation being stabilized by earth on the other side. I wonder if there is earth or air on the other side of this foundation wall. If it is air, I would want something to stabilize the structure.
Picture 100_1129
While this is likely carrying the load from the deck, my concern would be that the extension should be fastened to the lower larger column and the deck joist fastened to the extension top. Appearance wise it sucks, so on that note scrap the above and replace with one post. Picture Support Post Are any of the post out of plumb? The one behind the first coumn appears out of plumb, maybe its the photo angle. |
None of that would fly in my state. . . Maybe things don't move in Texas.
Still Termite bait. lol |
Worried about racking this can be controlled under the deck with BIG X fastened on the under side on the Joice's . Not to columns . This is a disaster not fastened to the deck and the small extensions. Posts in soil will rot out . Write it all up. Could fall out with a few kids doing what kids should do . I find many decks are not built correctly and they are an accident waiting to happen . These are where big liability claims are launched Roy Cooke If I can answer any questions please send me email Roycooke@hotmail.com On an inspection and need immediate help call my cell 613-827-2011 Last edited by rcooke; 12/10/06 at 6:13 PM.. |
The masonry block wall sits on a concrete pier, and there is air on both sides of masonry block wall. The following 2 pic may give some perspective. The posts pics were taken inside opening of block wall.
The floor joists are nailed to the top of the posts,,, similar to beach house construction,,, but those are usually bolted. The posts are pressure treated. |
very poor design, no engineer would design that.
I would recommend an engineer on this one. |
Are you sure that house wasn't across the border into Mexico?
I have seen treehouses and childrens play-structures that looked better engineered than that....and far more secure looking as well.
The key phrase here is "looking". As I am not an structural engineer, I would definately call for another look. Brian R. Sumpter First Call Inspections Proudly serving most Bay Area Counties www.firstcallinspections.com |
tmels is a non-member guest and is in no way affiliated with InterNACHI or its members.
wow that is scary looking
Linda
Surely these posts are temparary supports until the Builder is ready to set the finished product. The pictures are indicative of backyard construction. |
bjones1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
| Return air from crawl space | WHI | Inspecting HVAC Systems | 11 | 1/9/12 8:43 PM |
| Crawl space in under house | dnasser | Structural Inspections | 15 | 2/27/07 8:12 PM |
| Manufactured home crawl space | sstanczyk | Structural Inspections | 2 | 2/19/06 5:23 PM |
