Old 9/27/09, 3:59 PM
Michael J. Merino's Avatar
Michael J. Merino Michael J. Merino is offline
Default Technical name
I can't remember the name of these. I know it is to stop rafter spread. They are in the garage, first 2 rafters only. Is it just called a tension cable?
Michael Merino
Merino's Home Inspection & Education Inc.
"Not just an Inspection, an Education"SM
Phone/Fax 708~535~6057
Find an InterNACHI certified Arizona Home Inspector (and anywhere else in North America)
Old 9/27/09, 4:35 PM
John Onofrey's Avatar
John Onofrey John Onofrey is offline
Default Re: Technical name
What you got there is wire strand that can be adjusted for tension via the "turnbuckle".
John Onofrey Licensed Professional Inspector
Houston Home Inspection
Houston Home Inspector
www.texasinspectors.net
John Onofrey
President, Grail Media, LLC
"Effortless Email Marketing"
www.homehintsenews.com
2007 INACHI Inventions and Innovations Award Winner
Free! Inspector Email Marketing trial click here
Old 9/27/09, 4:36 PM
Thanks John, I know what it is and how it is used. I just can't remember the technical name of the system.
Michael Merino
Old 9/27/09, 4:54 PM
Hey Mike, I don't know the name for them. Seems to me a ceiling joist should be there instead of some metal strand. That doesn't look like any kind of standard system. Looks like some serious overkill if you ask me.
John Onofrey
Old 9/27/09, 5:51 PM
bdoles2's Avatar
bdoles2 bdoles2 is offline
They may not have anything to do with structural. Might be some set-up the owner had for hanging items, etc... Since they are only on the first 2 rafters, seems kind of useless IMO.
Old 9/27/09, 6:18 PM
Michael, I don't know of any other name other than a tension cable at the moment, but this is a pure joke.
This small roof can't be pushing the walls out enough to warrant using a what appears to be a 1/2' or 5/8" steel cable.
The capacity of a steel cable that size is in the 10-12 kips alone.
The turn buckles used are under rated due to the un-welded eye section and open hook end.
The clamps are backwards arse and they have saddled a dead horse.
This set-up could indeed pick up a roof if one were to install a 4"x4" under the ridge down to 30" below the top of the walls and run the cable under it and tighten the cable. As the cable were to be tightened, the roof would go up accordingly.
Then the roof rafters can be modified to pick up the load and remove the cables.
Maybe that is what was done here and the cables remained.
Old 9/27/09, 6:32 PM
James F. McKee's Avatar
with the new looking wood in the front corner of that garage these cables might have been used to pull things back in position during a repair....perhaps someone forgot to open the door while entering or exiting the garage at one time....just a guess from looking at that picture
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 9/27/09, 7:26 PM
Brian E. Kelly's Avatar
Have not heard that in a long time Marcel.
Old 9/27/09, 8:01 PM
That makes two of us Brian. It makes a very long time since I was told it.
Old 9/28/09, 12:37 AM
Thanks for the info guys.
Michael Merino
Old 9/28/09, 12:41 AM
Jeffrey R. Pope's Avatar
It made me smile when I read it. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 9/28/09, 5:29 AM
I was never much of a Rigger Marcel, but I've seen it done once or twice. The things that stuck were, Don't walk under the load, stay out of the bite ot the line, and be very careful where you put your hands/fingers.
Old 10/4/09, 11:14 AM
pmacaulay pmacaulay is offline
Handy man rigging, look at the cable clamps, "never saddle a dead horse" the saddle of the clamp is on the dead end of the cable, not that it matters.Who knows what this guy was doing.
Bellingham Technical College Venue Update ssmith Inspection Education & Training 0 3/20/07 11:38 AM
Technical Reference Guide Vs Carrier Blue Book waksell Inspecting HVAC Systems 12 1/22/07 6:45 PM
Bellingham Technical College full 2007 schedule ssmith Inspection Education & Training 3 11/20/06 12:12 AM
Bellingham Technical College 2007 "regional" class ssmith Inspection Education & Training 17 11/9/06 7:50 PM
