Do you guys call these out when you see them in homes?
Typically I will state something like, the posts are not designed for permanent use unless labeled by the manufacturer, recommend replacing with permanent type posts such as steel lally columns. Though I have seen older houses that have had them there for 20 years. Scott Falvey Clear View Home Inspections, LLC Newbury, NH NACHI#05051292 www.clearviewhomeinspectionsllc.com |
Hi Michael,
Good info. thanks. Scott Falvey Clear View Home Inspections, LLC Newbury, NH NACHI#05051292 www.clearviewhomeinspectionsllc.com |
Found this is a $1M foreclosure in the garage under the house - since the 3 2x6s weren't holding up the house, they added a jack post to help - neither the top nor the bottom plate were atttached - both were suseptable to being hit by a car - but then again, what can expect for only $1M?
| A steel House | rcooke | Canadian Inspectors | 4 | 3/20/08 12:42 PM |
| disimilar metals | cbono | Canadian Inspectors | 6 | 1/15/08 8:41 AM |
| Steel post question | sspradling | Structural Inspections | 42 | 3/2/07 9:59 PM |
| Dave Bottoms is a slme Ball | rcooke | Canadian Inspectors | 4 | 10/11/06 10:01 PM |
