Old 7/16/08, 6:11 PM
bdoles2's Avatar
bdoles2 bdoles2 is offline
Default Is there anything code specific to water proofing or damp proofing?
Is there anything code specific to water proofing or damp proofing a poured concrete foundation.
I see two different methods around here -
One being just the spray on rubberized asphalt with the drain strip at the base - then backfilled. there-anything-code-specific-water-proofing-damp-proofing-img_7538.jpg
Second one is the same as above except immediately after the asphalt is sprayed, sheets of rigid fiberglass are placed on the asphalt -then backfilled. there-anything-code-specific-water-proofing-damp-proofing-waterproofpic1.jpg
Anyone have any comments on the pros or cons of the above applications? I couldn't find any code related to water proofing a poured concrete foundation, but I'm sure it's out there.
Old 7/16/08, 6:34 PM
Unmoderated Guest
Default Re: Is there anything code specific to water proofing or damp proofing?
Dampproofing is required by code. Waterproofing is not.
Old 7/16/08, 8:54 PM
john bubber john bubber is offline
Unmoderated Guest
Please Note: john bubber is a non-member guest and is in no way affiliated with InterNACHI or its members.
Good man Richard
here is what Timmy C says about waterproofing/damproofing/codes... http://www.askthebuilder.com/NH058_-...ndations.shtml
http://www.askthebuilder.com/015_Ext...proofing.shtml
Timmy is an arrogant sob, my 2 cents BUT...he gets an A- on those 2 links
Apparently,he`ll fly out to anyone house and give ya his 2 cents for $4,995 but ya gotta take him out fer DIN DIN or cook him up something real good. Eh, shtt...i`ll drive out to some peeps homes for fk`g free, well, you pay da gas man! Wow, $4,995 is a nice chunk fer a day or 2....maybe i outta hang up my shovels, get fat and start my own website and shtt like others
My 2 cents.....NEITHER of those pics is WATERPROOFING.
From EOF in Canada eh.... http://www.e-o-f.com/foundation.html#DRAINAG
lol..... Contrary to the code this 2000 house built in Kingston fails in that...
1,2,3,4.....foundation walls aren`t up yet, and there are four major code violations. lolol ...gotta say, quite a few builders and their subs are more than several sandwiches short of a fkg Yogi Bear picnic, and lets not forget some of those city inspectors...got MILK?
http://www.e-o-f.com/foundation.html#SCAMS
These products or methods are not intended to stop water and...they don`t
a) damproofing (tar only) is not waterproofing
b) drain clad (reddish or yellow FIBERGLASS boards) is not waterproofing <-----------------
c) system platon(heavy black plastic mats with bumps on one side) is not waterproofing
refers to following as frauds...got MILK? Well do ya
d) water control is not waterproofing
e) a sub drain system is not waterproofing
f) bentonite injection is not waterproofing
g) a pressure relief system is not waterproofing
ummm, INSIDE SYSTEMS ain`t freakin waterproofing.
Then we have those builders/city insp`s who don`t read/listen to drain tile manufacturers recommendation of NOT using black plastic flex perforated drain tile at/around DEPTHS greater than 4'. Most basements/footings are 5 1/2,6,7' deep yet MANY builders/subs use this black plastic perf tile along exterior footings and city insp`s apparently OKAY`s this shtt.
http://www.oxfordplasticsinc.com/perforatedpipe.htm
scroll down to ummm, SELECTING PERF PIPE...
"As general rule of thumb we do NOT recommend the use of flex plastic pipe at depths greater than 1.2 meters.....the load (weight) of the backfill material would cause a flex plastic pipe to collapse"
Yet, as i say and know/seen, quite a g dang few have been, still are using this CHEAP AZ shtt on new/newer homes...more money in their pocket and faster to lay this light/cheap shtt down there.
This must be OKAY in all the different citys we`ve seen it used, city inspectors apparently are A fk me OK with it. I`d like to see these morons slapped w/class action lawsuit,just on the use of this drain tile garbage, would make Bubber-man fkg happy and would prolly get a smile on the face of the great `n late George Carlin! I`ll take one George fer every 1,000 builders, the arrogant sobs.
Home Inspector Listings jbowman Miscellaneous Discussion for Inspectors 230 3/21/12 9:35 PM
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 9:24 AM
Garage/house fire door Steven C. Meyer General Inspection Discussion 15 2/5/08 7:06 AM
