bdoles2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
A basement in todays house. I felt like a mouse in an obstacle course. I was surprised to see this. Most houses of this size at least have the basement framed for future finish. Not this one, just about 30 6x6's everywhere. And yes they are resting on the slab, just waiting to be kicked out.
What ever happened to metal I beams and posts??
Peter Doane Realty Check Inspection Service NACHI ID# 05120681
Amazing.
Brian, sure would be curious as to what the design drawings looked like on this one. Or, was it designed by your local farmer turned Contractor? ha. ha. Maybe it was a 8" structural slab where you need not provide a base footings for all those toothpics. ha. ha. Marcel </IMG></IMG> LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Brian;
If the client is willing to stoop to Home Depot, I guess they can live with anything out of the standard and would not know the difference, right? ha. ha. Marcel </IMG> LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Are those post maybe temporary? They sure do look close together/
"I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison www.newbeginningshomeinspection.com |
homebild is a non-member guest and is in no way affiliated with InterNACHI or its members.
How do you know there aren't the required footings below the slab?
It usually isn't possible to tell footings are in place once the slab has been poured... How do you know the columns are not restrained against lateral movement? A common practice with wood columns is to set a steel anchor into the concrete footing but have it project up above the concrete, bore a hole in the middle of the column base, then set the column over the bolt. This is a code-compliant means of laterally restraining columns against horizontal movement. (R407.3 2006 IRC) |
wforsyth is a non-member guest and is in no way affiliated with InterNACHI or its members.
Now you tell us. How'd you know a realtor was buying it?
| Dr. Shane says every home should be tested for mold. | gromicko | Ancillary Inspection Services & Additional Topics | 106 | 6/7/09 3:36 AM |
| Grab Your Checkbooks - For sale: 2 million empty homes | jburkeson1 | Miscellaneous Discussion for Inspectors | 2 | 10/26/07 7:22 PM |
| Pati Parisi, Broker, CRS, Million Dollar Club, speaking at Oregon meeting with me. | gromicko | Miscellaneous Discussion for Inspectors | 0 | 2/1/07 1:39 AM |
| From Million Dollar Estates to the GHETTO!!!! | jwatts1 | General Inspection Discussion | 25 | 9/5/06 6:59 PM |
