If you look closely, I hope you can see that the top chord extension is also being used as bearing. There is nothing suporting the truss joists on the bottom.
I am not used to seeing this method and wanted to see if anyone knows if truss joinsts can now be engineered this way. Thanks, |
| Need a home inspection in New Jersey? Check out InterNACHI's listing of New Jersey certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
New construction? Did you ask for the truss design documents?
Was it a heavier load area?
Thanks for the responses...This is a tract builder and he does not have to give me the truss engineering. I could track down the truss builder and pass it by them, or possibly another designer... I have never seen this method approved so it is getting my attention.
Larry, you say that this is not uncommon? |
Yes, that's right. This is what I see around here often (or similar):
Not Uncommon
See it often primarily with Townhouse and Condominium construction. Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
Marvin, the only definitive answer for this new construction is to be found in the structural drawings and the truss shop drawings.
These documents are required to be available on site. Pete Campbell pete4545@comcast.net http://www.PortStLucieInspections.com http://www.ChooseGI.com http://ifwemissitwewillfixit.com Inspecting Fort Pierce, St. Lucie Village, Lakewood Park, Vero Beach, Indian River Shores, Sebastian, Fellsmere, Fort Drum, Okeechobee, Jensen Beach, Stuart, Palm City, Hobe Sound and Indiantown, Florida. |
Top hung trusses are very common in commercial construction. I have installed them numerous times. Plumbers and electicians love them as it is easy to install there water and wiring. Just make ure they have a continuos 2x4 or 2x6 on each upright between the webs.
Greg Mathias, CCHI Journeyman Carpenter Global Property Inspections Lloydminster, AB. Canada (780)205-9912 |
Its very difficult to comment on floor truss bearing without the drawings unless there are signs of movement or apparent missing/added members.
Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
I agree with Robert and Gregs comments on the design. The contractor does have to show the info but not to a HI. If you are on site for consulting you need another HAT so to speak.
THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
| Where do I put the Aquarium? | mcyr | Structural Inspections | 3 | 11/6/07 3:05 PM |
| Bearing wall support modifications | bwooddell | Structural Inspections | 1 | 5/18/07 11:44 AM |
| Insufficient end bearing? | jclark1 | Structural Inspections | 3 | 9/12/06 1:43 PM |
| Proper End Bearing..? | crichiii | Structural Inspections | 14 | 8/28/06 8:47 PM |
