Old 9/18/07, 8:24 PM
Jeffrey R. Pope's Avatar
Default Triple Truss
A damaged truss is bad enough. This is a triple on a relatively new (2004) home.
I have no idea how it happened. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 9/18/07, 8:49 PM
Michael Larson's Avatar
Default Re: Triple Truss
Heavy equipment damage either before or after installation. I suppose they figured they would be long gone before anyone found it.
Old 9/18/07, 8:56 PM
cgoyette cgoyette is offline
Please Note: cgoyette is a non-member guest and is in no way affiliated with InterNACHI or its members.
Going way out on this one---how about earth quake...tree fall damage....looks almost like it twisted and if so may have been real wet wood and dryer then cracked as seen.
Again total guesses but thought you may want to here even a guess.
Curt
Old 9/18/07, 9:31 PM
My guess would be that they were damaged prior to installation. The damage was too isolated to be from an earthquake (IMHO), although we did have a recent jolt that could have contributed something.
The triple appeared to be the shearwall bridge supporting a vaulted ceiling and a concrete tile roof. . .
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 9/24/07, 6:15 PM
bjones1 bjones1 is offline
Send a message via MSN to bjones1
Please Note: bjones1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
[quote=jpope]My guess would be that they were damaged prior to installation.quote]
I've seen a lot of trusses get broken when they're delivered. If a single set is sent on one truck, they ususally raise the bed and let the trusses slide off. A wrong move and the bottom 1 or 2 trusses get broke.
I've also seen trusses get broke being hand-bombed from the ground to the roof. truss falls, or gets caught with another as it's being lifted.
Also seen them broke being lifted by a crane. Truss gets snagged, operator doesn't see it and keeps going.
Old 9/24/07, 7:54 PM
From what I can see, this truss was picked up by a forklift on the flat, or picked up with a Crane on the flat to move from one location to the other, or was unloaded on un-level ground from the slide off beds.
Too many variables here, truss is damaged before or after install, and the integrity of the structural capacities have been hindered, recommend a truss Manufacturer or structural engineer to evaluate.
Marcel
</IMG></IMG>
Old 9/24/07, 11:27 PM
The trusses stored were onsite waiting to be loaded when the bottom chords received an impact. It could have been the lift (rough terrain forklift) which ran into them or they could have been dropped and damaged during the setting process.
It doesn't really matter although it's fun to try to figure out. Report must specify evaluation by a structural engineer since their structural integrity has been comprimised.
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 9/25/07, 12:28 AM
Scott Schultz Scott Schultz is offline
Please Note: Scott Schultz is a non-member guest and is in no way affiliated with InterNACHI or its members.
It's pretty simple to repair broken trusses like these and bring them back to their original load strength. The plan for repairing that truss must be posted though so that it can be confirmed it was done to spec. Not sure if a SE has to be called in unless the repair specs cannot be located by the builder.
Old 2/9/09, 8:57 PM
Mike Truss Guy's Avatar
Mike Truss Guy Mike Truss Guy is offline
Please Note: Mike Truss Guy is a non-member guest and is in no way affiliated with InterNACHI or its members.
It's simple to repair a single ply truss. Repairing a three-ply girder truss with no visible bracing on the chord might be near impossible.
Best Truss Repair Ever!!! srowe Exterior Inspections 2 10/24/06 9:05 PM
3-2 mono roof truss anchor dthomas2 Structural Inspections 8 10/2/06 11:36 PM
New Truss Setting System jbowman Structural Inspections 1 6/14/06 11:10 PM
