Old 3/20/06, 5:43 AM
nbhi's Avatar
nbhi nbhi is offline
Default Truss?
Does anyone see what I see? If so, how would you write this up?
Thanks
Attachment 2237
"I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison
www.newbeginningshomeinspection.com
Old 3/20/06, 5:58 AM
gbeaumont's Avatar
Default Re: Truss?
Thanks
Attachment 2237
Hi Gary,
it does appear that the second truss has been modified, if it indeed has it should be written up that trusses may not be modified without engineering approval.
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 3/20/06, 6:15 AM
twheeler
Guest
Posts: n/a
Default Re: Truss?
I'm not sure modified would be the correct terminology. Damaged maybe, and never repaired properly. In any case, recommend a structural engineer be contacted to assess.
Old 3/20/06, 11:16 AM
ccoombs's Avatar
ccoombs ccoombs is offline
Please Note: ccoombs is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Truss?
What Tyrone said.
Old 3/20/06, 2:44 PM
Default Re: Truss?
IRC R802.10.2 Trusses are engineered systems. The components of each individual truss-- webs, connectors, gusset plates, straps, clips, and fasteners -- and all trusses in a roof are designed to perform together as a system. Field alterations to the truss system should be reviewed and documented by a structural engineer. In most instances, un-approved field alterations to a truss system voids the manufacturer's warranty for the entire truss system.
I recommend that you ask the sellers to show you any documentation that the alterations were done to a structural engineer's specifications.
If you cannot confirm, in writing, that the trusses were correctly modified in accordance
with an engineer's specifications, recommend that you have a qualified structural engineer review the trusses, then develop and implement a written plan for repairs.
Old 3/20/06, 6:31 PM
twheeler
Guest
Posts: n/a
Default Re: Truss?
Codes are slightly different in The Great Country the US. But in the end, we still recommend the same people.
Old 3/20/06, 9:47 PM
Jay Moge's Avatar
Jay Moge Jay Moge is offline
Default Re: Truss?
how about that thing (i forget it's name, for now i'll call it "thing") fastening the 4 truss boards together? is it an issue that only half of any board is used for attaching to the whole assembly?
Old 3/20/06, 10:26 PM
Doug Edwards's Avatar
Default Re: Truss?
You mean the gusset. Yes this is perfectly normal. If you have never seen how trusses are manufactured you owe it to yourself to go to a truss company and watch. These are rolled through a press and the gussets are pushed into the wood. Dang near impossible to remove one
Old 3/20/06, 10:50 PM
Jay Moge's Avatar
Default Re: Truss?
GUSSET, that's the word. i had a greesy lunch and that word must have slipped off.. thanx. i see it all the time, but wonderd if it was efficiant. thanx Mr. Edwards.
Old 3/20/06, 10:59 PM
Joseph Hagarty,  CMI's Avatar
Default Re: Truss?
Thank You....
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 3/21/06, 4:37 AM
Russel Ray's Avatar
Default Re: Truss?
That's one of the great understatements of 2006.
Old 3/21/06, 4:41 AM
Russel Ray's Avatar
Default Re: Truss?
It actually says that in the IRC? Wow. I don't think I've ever read anything so coherent in a code book. I read the code books all the time—to put me to sleep. I guess I fell asleep on that page.
Old 3/21/06, 8:08 PM
Default Re: Truss?
Dont' matter what part of the Country you are from, when you start messing around with Manufactured Engineered Products, the Engineers need to be re-called or notified of any modifications to an engineered sysyem.
If no disclosure was up-fronted, request a structural engineers' recommendation of the falter modification.
Marcel
Best Truss Repair Ever!!! srowe Exterior Inspections 2 10/24/06 9:05 PM
3-2 mono roof truss anchor dthomas2 Structural Inspections 8 10/2/06 11:36 PM
Nah...Who needs that TRUSS anyway ! pabernathy Structural Inspections 9 7/10/06 8:20 PM
New Truss Setting System jbowman Structural Inspections 1 6/14/06 11:10 PM
