Old 12/2/07, 9:57 PM
lfoster's Avatar
lfoster lfoster is offline
Question Truss bracing at roof hip
I have a question. After searching the archives,,,,
This home is truss roof construction, two story, 2 years old - in the attic at the hip ridge, one of the 2x4 'short member lateral restraints' (?? ) was short, and another was sistered to it. The longer one is still too short to reach the truss, and leaves an open gap of 1/2"-3/4" with the nails showing between the two boards.
Should this be called for further nailing? remove and install longer sister board?
Thanks,
Old 12/2/07, 10:32 PM
rborders rborders is offline
Please Note: rborders is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Truss bracing at roof hip
Truss members are typically under both tension and compression. I would would recommend further evaluation by a structural engineer.
Old 12/3/07, 12:04 AM
asargisian asargisian is offline
Wow , they defently have a problem with that. as mentioned have an structrual engineer give their evaluation, that is not a good sign of contractors work.
Old 12/3/07, 2:19 AM
It's just a block providing backing for the roof sheathing at the hip, it's not part of an actual truss. Sheathing will span that little gap no problem.
You will waste someone's money of you recommend a SE. It's sloppy, but it's sloppy with a minor framing member which will have little effect on the structural integrity of the home.
If it really bothers someone, they can have a carpenter remove the lower block and replace it with one nailed effectively.
Not a big deal. I wouldn't put it in the report.
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 12/3/07, 5:29 AM
Shawn Rowe's Avatar
Shawn Rowe Shawn Rowe is offline
Well said Kenyon, you get a greenie! I see this on EVERY home I inspect.
Shawn Rowe, CMI
HomeFirst Inspection Services, LLC
- InfraRed Specialist (Level 1 & Building Science certified)
- Code Certified Residential Building Inspector
- Certified Master Inspector
-- Serving NE Florida, St. Johns, Duval, Flagler, Putnam counties --
Old 12/3/07, 5:34 AM
Exactly, I agree with Kenton's assessment.
Marcel
</IMG>
Old 12/3/07, 6:12 AM
lfoster's Avatar
Thank you Guys !!
Old 12/3/07, 7:24 AM
Neither would I...
Larry Kage, CMI
231 929 3525
Old 12/3/07, 9:25 AM
Michael W. Gault's Avatar
Michael W. Gault Michael W. Gault is offline
Originally Posted by lfoster
Thank you Guys !!
A small issue may arise if you did put that caption on the photo...
Explaining that the 'sloppy looking' work is okay....
I hate making excuses for some contractors, but you have to allay what may be irrational fears as a part of your job....
- Mike
Michael W. Gault, SC RBI 1728
A to Z Home Inspections
Charleston, Dorchester & Berkeley Counties in S.C.
NACHI05040682
www.atozinspector.com
(843) 442-9755
Charleston Home Inspector
Old 12/4/07, 7:10 PM
Robert M. Delre Robert M. Delre is offline
Please Note: Robert M. Delre is a non-member guest and is in no way affiliated with InterNACHI or its members.
I agree. I have been a new home carpenter for 20+ years. Not worthy of mentioning it. Besides, it was already approved by the building inspecter as the house was constructed only 2 years ago.
Old 12/4/07, 10:02 PM
Approval by C. of O. from the AHJ doesn't mean much since they miss things all the time but you knew that from your 20+ years experience.
Larry Kage, CMI
231 929 3525
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 8:10 AM
Ice Gaurd membrane dmacy Exterior Inspections 36 6/14/07 12:21 AM
Roof Repair? Maybe NO jhagarty Exterior Inspections 9 2/15/07 1:19 AM
3-2 mono roof truss anchor dthomas2 Structural Inspections 8 10/2/06 11:36 PM
Truss bracing jlybolt69 Structural Inspections 11 3/14/06 9:56 AM
