mnicholet is a non-member guest and is in no way affiliated with InterNACHI or its members.
I am doing an inspection for clay tile roof tommorow. Anything in particular I should look for in the engineered truss components to support the 1000lb per square load? Thank you.
I can't answer that directly, but if you can figure out manufacturer you may be able to look it up online before you write the report. Take lots of pics so you can exmaine them before report maybe.
If you can find it online it should give you some specs on capacity and span I would think. Just an idea. Ian Niquette Square One Home Inspection Markesan WI 53946 www.squareonehomeinspection.com Active Rain Network INACHI Awards Portal Want To Exchange Links? What we've got here is......failure......to communicate.....
Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Hi. Mark;
Dale is correct in what he stated. Trusses that are designed for asphalt or composite type shingles can have dead loads of around 7-10 pounds per square foot (psf). Trusses that are designed for concrete tile can have top chord dead loads of 15 psf or higher. If you have the original design information on the trusses you should be able to determine the top chord design dead load. If not, you should contact the truss manufacturer to request help on tracking down this information. Problem with that is, it might not be possible to know who the manufacture is unless you can find a stamp on the truss itself. This link, http://www.lbrspec.com/T-1_1.pdf will show you a typical truss design and state all the design criteria. This one in the lower right had corner, you will see where it states TC Dead load=10 This one is designed for 10 # per sq. ft. top chord. If this truss design was for it's original roof tile, there should be no questions. If this was a reroof from an original roof shingle, it could possibly be an issue. Find out if the house was originally built with clay tile or concrete tile, and note it as such and move on. If it was not original, again I would make note of the possibility the roof trussess were not designed for this type of roofing material and again, you did your job. Hope this helps. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
What Dale and Marcel said, and look for failure... like compression cracks in drywall. Properly-designed trusses are easily capable of supporting tile, but if there's been a change to a heavier roof covering material, additional settling in the framing is not uncommon.
Tab M. Wilcox is a non-member guest and is in no way affiliated with InterNACHI or its members.
I agree with Brian. Clay tiles will crack if you look at them too hard!!
| Building Science- research from respected sources | Brian A. MacNeish | Ancillary Inspection Services & Additional Topics | 17 | 7/12/11 6:31 AM |
| Truss Uplift | rcooke | Canadian Inspectors | 5 | 2/26/08 7:43 PM |
