Hi,
Need opinions on the following: 1996 home, slab construction Attic truss Numerous drywall cracks at top of wall / ceiling No cracks over doors, or over/under windows Blown-in attic insulation No vapor barrier Will the lack of a vapor barrier contribute to heat / moisture in the attic and encourage flex of the truss? Opinions welcome. Thanks, |
This Illustration shows that truss uplift is thought to be caused by moisture differences in the truss components. I would think a vapor barrier would certainly help prevent this, but there are others here who know these things for sure.
The lack of a vapour retarder/barrier has never been shown to contribute to the problem. An old style unsealed (read: very loose) ceiling retarder could still help contribute to the attic moisture if there was a very wet/damp house below due to a variety of problems; unvented dryer, bathrooms, kitchen; wet/damp basement/crawlspace, high numbers of plants,aquariums, etc; interior stored wet firewood. The unsealed nature of the retarder allows a significant flow of house air containing moisture up through the ceiling penetrations and loose fibrous insulations to the cool sheathing where it may condense.....but it, at least, adds to the general RH of the attic and to the wood expanding due rise in moisture content. In humid maritime climates, research has shown the attic venting actually increases the amount of moisture gained by the wood above the insulation!! |
When the moisture and air leakage from the house contribute to part of the increased moisture load in the attic wood, the first attack is to dry out the house so that there is not excess moisture in the air and then airseal (create an air barrier) at the ceiling level to stop house air containing moisture (and heat) from getting to the attic. The lack of a vapour retarder/barrier has never been shown to contribute to the problem. An old style unsealed (read: very loose) ceiling retarder could still help contribute to the attic moisture if there was a very wet/damp house below due to a variety of problems; unvented dryer, bathrooms, kitchen; wet/damp basement/crawlspace, high numbers of plants,aquariums, etc; interior stored wet firewood. The unsealed nature of the retarder allows a significant flow of house air containing moisture up through the ceiling and loose fibrous insulations to the cool sheathing where it may condense.....but it, at least, adds to the general RH of the attic and to the wood expanding due rise in moisture content. |
| Building Science- research from respected sources | Brian A. MacNeish | Ancillary Inspection Services & Additional Topics | 17 | 7/12/11 7:31 AM |
| Truss Uplift | rcooke | Canadian Inspectors | 5 | 2/26/08 8:43 PM |
