rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
And the winner is....
| Find an InterNACHI certified Minnesota Home Inspector (and anywhere else in North America) |
I see no reason for the cut truss to be there in the first place.
Is there something I can't see in the PIC? "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
After seeing the cut truss I looked around, as it seemed like it was "extra" since the spacing was about 8". Why would the add an extra truss, which they would cut anyways? ![]() Then I noticed that the other truss placements were not 12"OC nor 16"OC nor 24"OC. The spacing was varried between all of them. Did I mention that the roof sagged? |
Ooooooohhhh!!
Same contractor as the gas pipe fitter on the other thread!? http://www.nachi.org/forum/f2/help-p...53/#post584953 "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
Like I said, quite odd.
| What's Inside A Chimney | mcyr | Inspecting HVAC Systems | 14 | 9/17/08 7:11 PM |
| Truss Uplift | rcooke | Canadian Inspectors | 5 | 2/26/08 8:43 PM |
| Difficult Chimneys | thance | Inspecting HVAC Systems | 2 | 1/29/08 9:16 PM |
| Chimney flashing photo's needed: brick and stone done correctly | kshepard | Exterior Inspections | 6 | 10/13/07 9:10 AM |
