jlybolt is a non-member guest and is in no way affiliated with InterNACHI or its members.
Home has an additional section of roof. Looking at the front of the home its the roof in the middle. They created this roof be building up another roof on top of roof trusses installed for the roof on the left. First time for me to see this. Wanted others opinions. Any carpenters out there? First picture is a side profile , notice the xtra framed roof above the hip truss. 2nd picture shows you the exterior roof and 3rd picture is from the scuttle looking up towars the peak.
Bracing for the trusses? Deals with the multi-levels on roof?
I haven't seen this before, either. |
I really cant see anything wrong with it. The roof above was framed correctly to a hip rafter.
where are the carpenters when you need them.
Looks OVER framed James....nothing wrong with that...!!!!
Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
I don't see anything wrong with it either, other than it is a ridiculous design. Architects just seem to like to complicate things when simplicity makes more sense. Oh well, it gives framing contractors and roofers more work, they make more money this way...
Helm Home Inspection David Helm, Owner/Inspector http//www.helmhomeinspections.com |
It may be over framed, or it may just be over lumbered. If the latter, it rates a careful look for structural soundness, as the framers may not have known what they were doing. The second picture gives the impression that the trusses are not plumb, though it may just be an illusion of the camera angle.
Jim King |
bjones1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Looking at the pictures, it appears that the girder trusses may be the wrong pitch, or undersized, hence the build-up. Scenario 2 would have the builder or owner changing the design mid-stream and rebuilding on top of the girders to give a multi-leveled roof design, more esthetically pleasing.
IMHO |
Overframes are a common method of supporting a roof.
You frame (or roll the trusses) and sheath the first roof... in this case the furthest roof back... and that roof supports part of another roof. I can't tell from the pictures if that's what this is, but your post describes an overframe. I see a girder, rafters and a lot of bracing, but I don't see a hip truss. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
The pictures are hard to comprehend in framing techniques, and can only say that it is a convoluted framing mess.
I believe Kenton is trying to say that it is normal for framing Contractors to build the main roof truss systems with sheathing and then proceed to build on top of that main roof, additional roof dormers or gables to look like the one in the picture. It appears that all this double framing, although might be structureall sound, might not be the most economicall and cleaneast. It also appears that some of the double framing is or are creating pin point loading on some of the trusses below that were not meant to carry this type of loading. It would be hard for me to perceive that roof system as depicted in the picture was actually designed by a truss Manufacturer. JMO Marcel </IMG></IMG> LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Yep, what Marcel said. That roof has confusticated framing. The pictures make my head hurt.
Kenton, no hip truss but a hip rafter yes. The trusses extend left to right of the struture. Basically the higher roof in the middle is not supported by the truss but by conventional framing ( rafters and hip rafter) which was framed over the truss. Its looked structurally sound.
I took one more look and I think I understand.
It is an overframe. Typically they frame and sheath the first roof, then use that to support framing for the second roof. Framing for the second roof would usually rest on sheathing. In this case they didn't sheath the first roof, but framed the upper roof right on top of lower roof framing. That's why it looks so complicated in the picture. Well... not the only reason. It looks like they used unique framing methods for the upper roof, but as long as it looked solid and felt solid there's nothing to call structurally. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
only photo I could find
![]() imagine hip roofs, only with no sheathing. Also, this is not built well. The bottoms of those jack rafters should rest not directly on OSB, but on a pair of ledgers, one on each side, nailed right to the roof so that when it's sheathed they'll have solid sheathing nailing at the valley to help hold the roof down in high winds. Each sheet of sheathing on a roof should have solid nailing around the entire perimeter of the sheet. As it's framed now, sheathing will be nailed to each rafter, but the overframe will only be connected to the main roof by a few toenails through the bottoms of the rafters. Most roof are blown off not by wind getting under them and lifting them off, but by extreme low pressure created on the downwind side of the roof. The roof is sucked right off the house. It's the same principle that moves a sailboat through the water. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
Kenton, besides the fact of no ledger board for the jack rafters as you pointed out, it appears the OSB sheathing was installed parallel to the rafters. Is it the picture or is that the way it was done?
Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
| Spanish tile roofs | bmiller2 | Exterior Inspections | 15 | 1/29/07 7:15 AM |
| Florida Insurance company seeking NACHI members in Fort Myers (shutters + roofs). | gromicko | Exterior Inspections | 0 | 9/29/06 2:16 PM |
