FYI - The attached drawing was developed for a settlement/cracked foundation issue for one of my clients. Free for anyone to use if needed.
| Need a home inspection in Illinois? Check out InterNACHI's listing of Illinois certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Randy,
Looked at a commercial building with CMU construction 2 story built in 1992, last week. No basement. 4' footings. They did know about bad soil in one area. They thought it was corrected before construction. Expansion joints every 20 feet. The back wall (about 30 feet wide) has a separation of the expansion joint and adjacent attached window second floor of almost 1 inch. The corner of building is sloooowly sinking. Your illustration brought that settling to mind. Good pic. |
Thanks Randy. Nice graphic.
Marc
The photos attached, from one of my clients, shows the foundation of a house that was jacked up with push piers to correct for settlement on unconsolidated fill. The house was raised about 1.5 inches. |
What is the next step, to fill the void created? What method is used? Jeff Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
Jeff
The excavated soil was replaced and compacted. No attempt was made to fill the gap. The push piers are now supporting the entire weight. The interior slab was floating independent of the footing and stem wall. This end wall now acts like a grade beam and pier foundation. |
That would be something to see first hand. Really interesting.
Thanks for sharing the 2 photo's. That is a lot of weight. |
I often specify/design either push piers or helical piles, and sometimes underpinning in certain circumstances, for settlement on cut-and-fill construction if it hasn't stabelized (tough call sometimes).
Attached is an old NACHI TOD graphic on cut and fill settlement and some repair graphics ... Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
Great info. Thanks guys.
Once a building is determined that in fact there is a footing or soil issue. You determine these devices are to be used. How do you determine the depth of the pier or pile? Bore testing? Is there a typical building age that warrants a pier or pile? Is it more to do with storm or water washout around footings and slabs? Or?
If you can suggest a good read on the subject can you forward a link. Thanks |
http://www.pieuvistech.com/html/en/about.php Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
I expect they were added before closing .... Roy C http://www.caproco.com/catalog/pdf/R...e-Supplies.pdf Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. Last edited by rcooke; 6/26/11 at 3:45 PM.. |
Roy,
Thanks for the links. Just read a few things on them. Makes sense in Canada. You can use them all year round weather conditions. Indicates they can be removable. Why would you want to remove them? |
Any access to pics Randy? Nice pics BTW.. you've posted a few over the last year or so.. do you make yourself or have a library? |
Tim
This house was inspected by another home inspector that noticed a 1/4" crack in the drywall at one corner in a basement bedroom. Plus he performed a crude floor level survey on the main floor showing some elevation differences that turned out not to be structural. The buyer backed out because of his report and I was called in by the owner to give an over all structural evaluation. In general the concrete workmanship in the basement/foundation was among the worst I have seen. Nothing was square or level....so I spent more than the normal amount of time figuring out what was settlement and what was just poor workmanship. For example the foundation wall that was jacked up was about 3 inches out of square in 40 feet. Plus the basement floor slab has poured as much as one inch high and one inch low in spots. The original floor level survey elevation differences was just a reflection of a poorly finished basement floor slab and not any structural issue. So without knowing the "as built" elevations I was forced to have some of the drywall in the basement removed to expose the stem wall and lower half of the stud wall. Once exposed the problem became apparent, the stem wall had obviously rotated. The rotation was confirmed by the gap between the slab and the stem wall and the rotation of the stud wall that was on top of the stem wall. The root of all the problems was poor exterior water management which saturated the unconsolidated fill. The answer to your second question, I do all my graphics in Corel Designer. |
| Toilet Fill Valve | jallingham | Plumbing Inspections | 5 | 7/1/10 12:10 AM |
| Unsuitable fill dirt causing foundation to crack, suit says | ccurrins | Structural Inspections | 13 | 3/25/08 6:26 AM |
