| Structural Contains discussions about the structural portion of a home inspection. This includes foundations, framing, et cetera. |
I see quite a few of these straps in attics of newer homes and it seems as though 50% of them are usually broken.
Are they there for temporary support as the roof is being built? All these homes have concrete tile roofs. |
badair ADAIR INSPECTION 972-487-5634 Residential-Commercial-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes...accept the good |
rcooke is a non-member guest and is in no way affiliated with InterNACHI or its members.
Thanks Gary and Barry good information we all learn all the time .
Thanks NACHI .... Cookie |
The contractor usually tries to remove them for the next house truss installations, some get broke, some they forget about and leave. They are basically temporary spacing until the OSB is attached. Dale Duffy 602.402.5305 Inspect Arizona Companies, Inc. Phoenix Home Inspectors, Inc. Your Leaking House-- Your Leaking House Message Board InterNACHI 2007 U.S.A Member of the Year |
Dale is correct, and when you see those that are torn apart as these are, means that the spacing was altered, because there is no need to remove them after they are installed. In no way should they ever be reused. It is too dangerous. These spreaders are to facilitate the installation of trusses during erection and are meant to remain. They other dangerous thing about these spreaders, is Contractors rely on them to much in lieu of lateral bracing during erection and that is when we hear about all the truss collapes. Usually they are intact, if seen otherwise, note it as you did. Marcel Cyr Home and Commercial Property Inspections IAC2 Certified NACHI04070211 http://co.nachi.org/inachiawards Commercial Builder CertainTeed Master Shingle Applicator Shingle Technology Ouellet Associaties Inc. http://www.oaconstruction.com/ |
| A little on the Commercial side of things. | mcyr | General Inspection Discussion | 457 | 8/1/09 11:50 AM |
| Cracked shingles | pwigle | Exterior | 54 | 4/24/09 12:52 AM |
| Chimney flashing photo's needed: brick and stone done correctly | kshepard | Exterior | 6 | 10/13/07 9:10 AM |
| Roof Repair? Maybe NO | jhagarty | Exterior | 9 | 2/15/07 2:19 AM |
