Old 1/3/11, 1:13 AM
Stephen P. Shockley's Avatar
Stephen P. Shockley Stephen P. Shockley is offline
Default Unusual cracks in the ground in crawl space
Other than the obvious in this photo (missing vapor barrier), has any one come across finding cracks in the ground in the crawl space? This crack in the ground started at the front of the home and went almost all the way to the back of the home. Didn't see any cracking in the foundation walls where it was starting and ending though.
Shore-Footed Property Services, LLC
Stephen P. Shockley
MD Licensed Home Inspector
410-726-3471
Salisbury, Md
Need a home inspection in Idaho? Check out InterNACHI's listing of Idaho certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/3/11, 8:16 AM
Gerry Pallotta's Avatar
Gerry Pallotta Gerry Pallotta is offline
Send a message via Yahoo to gpallotta
Default Re: Unusual cracks in the ground in crawl space
Looks to me at one time the soil was damp/wet and now that the ground has dried up it has cracked.
Old 1/3/11, 8:21 AM
Wayne B. Wilson's Avatar
I agree Gerry , we see a lot down here
Wayne Wilson
East TN Home Inspections LLC
865-256-1490
Old 1/3/11, 10:16 AM
Jamie R. Wilks's Avatar
Jamie R. Wilks Jamie R. Wilks is offline
I agree with Gerry & Wayne as well. I have seen this type of cracking, but only in very dry weather (which is not too common in SE Virginia). The good news, at least the crawl space appears to be dry.
Jamie R Wilks
North Star Home Inspections
VCHI #3380000351
InterNACHI #05081596
Old 1/3/11, 8:54 PM
Thanks for the comments/inputs gentlemen.
Regards,
Steve
Stephen P. Shockley
410-726-3471
Salisbury, Md
Old 1/3/11, 9:08 PM
Darin Redding's Avatar
Darin Redding Darin Redding is offline
I often see similar cracks like that down here in San Diego. I agree with Gerry.
Darin Redding, CPI
Housecall Property Inspections
san diego home inspection
rental inspection | warranty inspection
Facebook Like
darin@sandiegohomeinspect.com
619-663-8740
home inspector in San Diego, Carlsbad, Poway, La Mesa, El Cajon, Chula Vista.
Old 1/3/11, 10:46 PM
Casey Patten's Avatar
Casey Patten Casey Patten is offline
Good to see pictures like this. Here in MN, I rarely see crawlspaces; education from other areas is great!
Root River Inspections
Serving Rochester, Winona, Red Wing, Austin, Albert Lea and all Minnesota areas.
Vice-President, Southern Minnesota Chapter of InterNACHI
Direct: (507)254.1391
Web: www.arochestermnhomeinspector.com
Email: rootriverinspections@gmail.com
"The nine most terrifying words in the English language are: 'I'm from the government and I'm here to help'" - Ronald Reagan
Old 1/3/11, 11:11 PM
Jeffery L. Haynes Jeffery L. Haynes is online now
Types of cracks in soil are often determined by the mix of the soil.....ie. sand, clay, silty, loamy, etc...... obviously certain mixtures will result in greater cracking which may or may not affect the foundation.
I would be more concerned if cracking was prevalent throughout..........you noted that no foundation cracking was noted so based upon my I would simply note to any prior moisture infiltration which may affect the foundation / subfloor system.
regards
Jeff
Old 1/5/11, 11:40 PM
Those are exactly the types of cracks under houses that indicate a housing development built over an ancient Indian burial ground. Ever see "Poltergeist"? If I were you I would disclaim every system in this house because they are all about to fall apart. I saw that movie!
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Return air from crawl space WHI Inspecting HVAC Systems 11 1/9/12 7:43 PM
Mold in crawl space prussell Structural Inspections 4 3/10/08 12:53 AM
Crawl space in under house dnasser Structural Inspections 15 2/27/07 7:12 PM
