Old 10/22/08, 6:25 PM
John Evans John Evans is offline
Default Unusual Floor Joist Connection
The floor joists above the crawlspace were set several inches above the sill plate, resting on short vertical 2x4's. No joist hangers or obvious toe nailing to the rim joist. Also note the "support posts" in the photo. Has anyone seen joists set like these?
[Maryland Home Inspections
www.aimhomeinspection.com
Infraspection Certified Level 1 No. 7801
Old 10/22/08, 6:35 PM
Default Re: Unusual Floor Joist Connection
Yes, that method was often used to line up floors of an addition when the foundation wall tops varied.
They need some attention.
Larry Kage, CMI
231 929 3525
Old 10/22/08, 7:26 PM
Barry Adair's Avatar
Cripple wall code info I didn't check all references but it's a start
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 10/23/08, 12:23 AM
"Non-professional carpentry". Good work would have required them to build a short wall ("knee wall, pony wall, stub wall" different names all mean the same thing.
Call any sign of failure.
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 10/23/08, 12:42 AM
Joseph Hagarty,  CMI's Avatar
Carpenter Ant Frass present in photos 1-3
Joseph P. Hagarty, CMI
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 10/23/08, 10:32 AM
David P. Valley's Avatar
Did anyone probe that area?
Old 10/23/08, 10:56 PM
jkogel jkogel is offline
There may be or has been a leak here. Moisture stains on the underside of the subfloor and the end of the joist. Wood destroying Insects are attracted to soft spots like this. You don't need to identify the species, call it out and recommend a pest inspection in that area.
As for structural integrity of the joist and sill area, it has stood the test of time so simply "unconventional construction", IMO.
The last picture with the props looks like amateur retrofit and requires a repair by a qualified builder.
John Kogel
www.allsafehome.ca
Old 10/23/08, 11:02 PM
dbucknavich dbucknavich is offline
Please Note: dbucknavich is a non-member guest and is in no way affiliated with InterNACHI or its members.
How old is that building?
Old 10/24/08, 9:13 AM
Home was constructed in 1942, this crawlspace appears to be a later addition. The original home was built over a full basement. Water stains were old, the kitchen above was completely rebuilt. Actually did not find any significant soft areas by probing.
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 10:24 AM
Slightly unusual water heater location kweiss Plumbing Inspections 8 12/5/07 10:22 PM
Grounding rod connection from meter box fbartlo Electrical Inspections 37 7/28/07 1:30 PM
Unusual findings dmacy General Inspection Discussion 4 3/21/06 2:52 PM
