The column shown apparently is intended to add structural support to the second floor rear wall, which is set back from the 1st floor wall. I noted several issues, the screw jack does not appear to be welded or disabled to prevent movement, not secured to the beam. Also, I thought it should at least be set directly above the center column supporting the beam. The placement of the column may have been a late construction revision. Home built in 2006. Any input would be appreciated.
| Need a home inspection in Alaska? Check out InterNACHI's listing of Alaska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
It looks like it may be one end of a girder truss bearing and, with the wood surrounding it, it doesn't appear to be going anywhere although mechanical connections are typical there...JMO.
I would ask for blueprints of which I would not expect to find such configuration but such blueprints may lead as to the reasoning why such columns were installed.
(It may also simply have to do with a owner trying to get rid of squeaks) If it is being used for structural purpose and same is not on blueprints than a SE should be consulted. |
| Another way to support a house | dvalley | Exterior Inspections | 3 | 10/30/09 3:45 PM |
| Episode 28 - eInspections and Inspection Support Network | inxil | NACHI.TV Inspection Videos | 0 | 9/10/08 1:59 PM |
| Where do I put the Aquarium? | mcyr | Structural Inspections | 3 | 11/6/07 3:05 PM |
