Hello
I got a call from a client, for a home inspection, one of his main concerns was to check on a wall that was leaning towards the house (im thinking foundation) and causeing water damage. He was informed that it had been fixed. Has anyone had a similar situation happen ? thanks in advance Eragorn Northe Der Hous Inspector LLC Certified Home Inspector Mobile - 306.684.1748 www.derhouseinspections.com Last edited by aerb; 7/7/08 at 7:50 PM.. |
john bubber is a non-member guest and is in no way affiliated with InterNACHI or its members.
Cause of wall-leaning was...? It has been fixed.....any paperwork/guarantee on this supposed fix?
And water damage....what was supposedly done about that? Please don`t say an.... 'inside system' was installed. |
I dont know yet the inspection is tomorrow,
i was looking for possible heads up to what i might find, perhaps some one else had a similar challenge. Eragorn Northe Der Hous Inspector LLC Certified Home Inspector Mobile - 306.684.1748 www.derhouseinspections.com |
Homeowner may have covered the inside wall,maybe not. You might see something like this http://picasaweb.google.com/DrE.Geni...43394759519858 Wall anchors like these may/might give a lil support to inside wall 'where they were applied'...doesn`t mean poured/block wall still won`t bow in further afterwards, especially if the CAUSE hasn`t been diagnosed `n repaired/removed etc. The cause is often-not always, lateral soil pressure and or roots and or porch footing etc. If they/contractor put wall anchors up as in pic it doesn`t mean they diagnosed/removed the CAUSE and they didn`t waterproof exterior of wall, still leaking as ya. Ya might see beams or carbon fiber straps, again, does NOT mean contractor removed the cause and certainly doesn`t mean they repaired/waterproofed the leak/cracks etc. Couple stories....last one 'Timing matters'....an unsound basement wall BEHIND drywall http://www.jsonline.com/story/index.aspx?id=730483 You may see beam(s) or wall anchors etc inside and....see something like this http://www2.snapfish.com/thumbnailsh...6/t_=122238283 Walls were recently painted,see efflorescence,mold-mildew on walls. That crap is still there and will continue to be there because the inside system that was installed does not stop/prevent water from entering the cracks on exterior of block walls.Nor does it stop/prevent insects from entering the same cracks. Same here,first 4 pics http://www2.snapfish.com/thumbnailsh...6/t_=122238283 a few pics... http://www.lrb.usace.army.mil/missio...ex.html#Photos 2nd pic on left...lateral pressure CAUSING top of basement wall to bow in..(pilasters failed to brace wall) top 2 pics, crap done on inside...inside system and injection. Not good. Bill Murray/Caddyshack-golfing w/ Dalai Lama http://www.youtube.com/watch?v=tAZwC6LLThs Bill Murray/Caddyshack-Cinderella Man http://www.youtube.com/watch?v=bg8lS...eature=related Last edited by john bubber; 7/8/08 at 6:30 AM.. |
If a wall is leaning towards a house, it's got to be a retaining wall.
Sorta like this, but towards the house. ![]() Post pictures when you're ready. I'd like to see the issue. |
yeppers,maybe it is....clarify plz or just post pics when ya can as Mr V says.
I definatly will post pics , thanks for the info
Turned out that it was bad communication between realtor and buyer which traveled to me the HI, to be something completly different.
it was a sloping grade not a sloping wall, and yes the area had been fixed. wow what a difference Eragorn Northe Der Hous Inspector LLC Certified Home Inspector Mobile - 306.684.1748 www.derhouseinspections.com |
So we don't get pictures??
| Stupid ASHI legislatin in Washington DEAD. | gromicko | Legislation, Licensing & Legal Issues for Inspectors | 20 | 1/29/08 9:05 AM |
| Article on Commercial and Residential Inspections and Assessment | mcyr | Commercial Inspections | 2 | 8/6/07 1:26 AM |
