Old 6/29/14, 10:02 PM
Joe Stevens Joe Stevens is offline
Please Note: Joe Stevens is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Wall Overhangs Foundation
Hi,
I run into this every now and then and I wanted to see how you guys report this.
This is a poured foundation on a ranch home built around 1960. From the exterior the foundation wall appears to curve or bow inwards near the middle of the home at the front wall. There is about a 1 1/2" gap between the wall sheathing and the foundation near the middle of the home, however that gap reduces in size as it approaches the corners of the home where the wall sheathing is tight up against the foundation. At first glance it could appear that the foundation has been pushed inwards an inch and a half, however it could have also been built this way. No notable cracks were found, at least where it was visible, and of course the basement is completely finished so nothing was visible inside. Its a foreclosure so no past history is available.
Any advice on determining if it was built with a curve or if it has moved? I know on newer homes the floor structure is usually tied to the foundation, but on homes in this age range around here that isn't always the case.
Thanks.
Need a home inspection in Iowa? Check out InterNACHI's listing of Iowa certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/29/14, 10:22 PM
Larry Kage, CMI Larry Kage, CMI is offline
Default Re: Wall Overhangs Foundation
Originally Posted by Joe Stevens View Post
Hi,
Thanks.
It sounds like soil pressure where the wall is weak to horizontal stress in the middle of the run. The corners are reinforced by the perpendicular walls that help hold them back.
If the floor system was adequately secured to the foundation you would probably see an outward bow on the wall opposite. Did you see anything on the other side of the house?
Was there a drive along that front side of the house?
That much of a bow inward is substantial and needs to be reported and repaired to maintain structural integrity of the foundation wall by a qualified foundation contractor who uses the services of a structural engineer.
Larry Kage, CMI
whis11 @ charter.net
The above post represents my personal opinion.
Old 6/29/14, 10:30 PM
No driveway, no sidewalk, and properly graded soil at the front of the home. There was a similar gap at the rear wall of about 3/4" of an inch. The rear wall was visible inside the basement and there was no substantial cracks other than a hairline vertical crack with no displacement. My gut feeling is that it was built this way but I have no way of knowing. Either way it was written up as a further evaluation needed.
Old 6/29/14, 10:39 PM
That could have been built that way.
My guess would be that it was back-filled improperly and too soon.
We still had many good qualified trades people in the 60s...regarding the foundation wall pouring. But maybe not so much with the excavator. Hard to say, really.
Larry Kage, CMI
Old 6/29/14, 11:23 PM
Kenton Shepard, CMI's Avatar
Kenton Shepard, CMI Kenton Shepard, CMI is offline
Location: Cuernavaca, Morelos, Mexico, (from Boulder, CO)
Bad formwork, very common. Less common is premature back-filling which would crack concrete green enough to move that much. The only way to know for sure is to tear out some drywall and look for cracking on the inside of that wall. Since there's another wall with a similar problem and no crack, my bet would be on bad formwork.
If it's been like that since 1960 it probably isn't going to fail or change any time soon. That kind of condition would very seldom develop after 40 or 50 years.
Kenton Shepard, CMI
Director of International Development
Director of Green Building
EXPERT WITNESS SERVICE
www.hinarratives.com
052 777 246 4676 (preferred)
052 777 154 5451 Cell
INSPECTION SERVICES WORLDWIDE
Old 6/30/14, 9:02 AM
Claude Lawrenson's Avatar
Claude Lawrenson Claude Lawrenson is offline
As Larry and others have stated - premature backfilling of the foundation wall is often the cause. The foundation walls must be laterally reinforced either by the floor framing system or by an internal side temporary brace system.
This is more common than not!
Cheers, Claude Lawrenson NACHI03121515
Inspection Support Services Inc.
"Those who can do. Those who CARE teach" and truly understand What do teachers make ?
Unusual Things I have found rcooke Canadian Inspectors 894 4/29/14 5:41 AM
Horizontal cracks in foundation wall, got milk? john bubber Structural Inspections 0 12/21/13 3:49 AM
stucco wall moisture leak Unregistered Will AskNACHI.org Inspection Questions Forum 3 10/11/13 3:58 PM
Moisture Management mcyr Exterior Inspections 15 9/8/08 12:11 PM
980 Questions/Answers to the NHIE....Free! jbushart Legislation, Licensing, Ethics & Legal Issues for Inspectors 50 4/20/08 1:26 AM
