Old 5/6/07, 6:27 PM
Vince Santos's Avatar
Vince Santos Vince Santos is offline
Default Wall/Slab Cracks
Saw three cracks during today's inspection. One of the cracks on the south wall was patched, extended down to the slab and stopped at the north wall. The north wall had a crack approximately 1/8" wide and while it extended down to the slab it was hairline for the at the bottom two feet. I'm not sure why the first crack would have been patched and not the second unless the second crack happened after the fact.
I did not observe any wall crack or doors that did not line up with the frames and these crack tested dry. I'm leaning toward the following recommendation.
Moderate cracks (1/8 inch to 3/4 inch) and/or leaning were found in the foundation. This may be a structural concern, or an indication that settlement is ongoing. The client should consider hiring qualified contractors and/or engineers as necessary for further evaluation. Such contractors may include:
Foundation repair contractors who may prescribe repairs, and will give cost estimates for prescribed repairs
Masonry contractors who repair and/or replace brick veneer
Geotechnical engineers who attempt to determine if settlement is ongoing, and what the cause of the settlement is
Structural engineers who determine if repairs are necessary, and prescribe those repairs
At a minimum, recommend sealing cracks to prevent water infiltration. Numerous products exist to seal such cracks including hydraulic cement, resilient caulks and epoxy sealants.
I'm curious as to what some of you would recommend concerning this defect.
wall-slab-cracks-img_0088.jpg   wall-slab-cracks-img_0093.jpg   wall-slab-cracks-img_0094.jpg   wall-slab-cracks-img_0095.jpg
Vince Santos
StepByStep Home Services LC
(734) 748-9584
Providing Home Inspection Services to Southeast Michigan
facebook
ITA Trained and Certified
Old 5/7/07, 4:10 AM
Russel Ray's Avatar
Default Re: Wall/Slab Cracks
I'm not following your thought processes there. Where did you come up with "and/or leaning"? You recommend that the "client should consider hiring qualified contractors and/or engineers as necessary for further evaluation," but then you backtrack by stating, "At a minimum, recommend sealing cracks". I think your Client is going to be confused.
I think that "At a minimum, recommend sealing cracks" is not an appropriate recommendation for a foundation and/or wall that is "leaning." However, I still don't know how you arrived at "leaning."
Old 5/7/07, 5:19 AM
dchew dchew is offline
Your text sounds like you're recommending that your client retain the services of 3 or 4 different professions. I definitely would not recommend the "masonary contractor" by your own description since he only repairs brick veneers.
I would recommend that you defer to a licensed qualified foundation contractor and/or structural engineer. They in turn, may recommend the services of soils engineer.
Old 5/7/07, 7:42 AM
jlybolt jlybolt is offline
Please Note: jlybolt is a non-member guest and is in no way affiliated with InterNACHI or its members.
Be careful in who you recommend. You may have to end up eating the bill.
I would use-
- Signs of structural movement noted, suggest that an expert in this field be consulted for further evaluation of the structure and to provide suggestions as to what, if any, corrective actions should be taken.
your job is to observe and report
Old 5/7/07, 10:38 AM
Sorry about that. I did a copy and paste from my report info. I always edit the descriptions and get rid of the irrelevent information.
Vince Santos
(734) 748-9584
facebook
Old 5/8/07, 8:45 PM
Robert J. OConnor's Avatar
Having one crack patched and then another one that's not is suspicious.
Moderate cracks (1/8 inch to 3/4 inch) ...
WOW ... a 3/4" crack is "moderate" ... holy cra_ batman ... perhaps you meant 1/8" to 1/4" ...
JMO
Robert O'Connor, PE
LIU CW Post Adjunct Professor
NACHI Education Committee
www.reporthost.com/-rjo
Old 5/8/07, 11:51 PM
JMO
Nothing that wide. The cut and paste included several references that did not pertain to the issue, as I stated. I measured the crack at what l thought was the widest point which was 1/8".
Vince Santos
(734) 748-9584
facebook
Old 5/10/07, 11:57 PM
That looks like a big crack. The angle and severety remind me of what we see around here from differential settlement. Unless it were real obvious, and it doesn't seem to be, I'd recommend a structural engineer with all that cracking going on.
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Step crack leading to further cracks gmendes Structural Inspections 5 6/21/07 10:40 AM
slab no cracks: Brick veneer cracks gkoehl Structural Inspections 1 4/17/07 4:52 PM
