Old 9/21/11, 4:43 PM
David P. OKeefe's Avatar
David P. OKeefe David P. OKeefe is offline
Default Warped support
This is one of three wood supports (6x6) but the only one warped. House built in the mid 80s. How significant is this? Would a SE be necessary to determine if correction is necessary? I found no other issues.
David
InterNACHI #08051301
NYS Lic. #16000038229
NYS DEC Cert # T4865884
518-505-8305
HouseAbout Home Inspections
HouseAbout on Facebook
NY Capital Region Chapter InterNACHI
Need a home inspection in California? Check out InterNACHI's listing of California certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 9/21/11, 6:24 PM
James E. Braun, CMI's Avatar
Default Re: Warped support
It will probably get worse, just recommend replacement.
When lumber bows like this and is holding up a lot of weight, it will bow even more, causing what ever it is holding up to be more unlevel.
Braun Inspection Consultants
Serving Jefferson City, Columbia, Sedalia, Fulton and Lake of the Ozarks
Old 9/21/11, 6:59 PM
I don't see failure due to the bowing of the 6x6 member, but due to aesthetics, you might want to replace.
What I do see, is that they installed the post on underground sonotubes or some sort of footing and poured the slab around the post.
Even though the PT posts are rated for ground contact at .4 retention, I would recommend that the post be installed on top of the slab above the pier footing with the proper post base as manufactured by Simpson.
The expansion of the wood and the concrete cause the slab to break due to the narrow slab edge around the post.
The post should be removed, with the hole filled down to its foundation support, slab edge repaired and new post installed on top of the slab with proper post base support.
No need to recommend an SE here. Just recommend a qualified builder to correct.
Old 9/21/11, 7:13 PM
Thanks for the help. I'll recommend replacement with Marcel's recommendation.
David
518-505-8305
Old 9/21/11, 7:30 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
Marcel:
I do not agree with this not having catastrophic failure. There is a great deal of weight in that over hang being supported by 6x6. This should be either changed to two or one 8 inch round.
I do agree with the break out on the slab and no you do not need a PE.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 9/21/11, 7:34 PM
David, I would not comment on how it should be repaired. Leave that up to the qualified builder.
Recommend replacement.
Old 9/21/11, 7:36 PM
KEVIN WOOD's Avatar
Agreed.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 9/21/11, 7:37 PM
Originally Posted by kwood View Post
Marcel:
You are allowed to voice your opinion, but in mine oppinion, I do not see a problem here unless there is a 90 mile wind. The weight on those post from what I see is miniscul for a 6x6 post.
Old 9/21/11, 7:49 PM
KEVIN WOOD's Avatar
It all depends on what that overhang is made of. From what I can see there is one 6x6 supporting 10-15 feet of over hang. If it was not bent I would not make any mention of it.
Since it is holding the whole section and may be attached by nails this makes it even worse.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 9/21/11, 7:54 PM
Kevin, again that is an opion and mine is that it should be left to a qualified builder to assess and evaluate the condition. We do not see the whole picture from those pics.
Do you know how many kips a 6x6 x8' high can support?
Old 9/21/11, 9:25 PM
Pete Campbell's Avatar
Pete Campbell Pete Campbell is offline
Good question, David. No SE needed (and try not to rec. SE too much, after all, that is what you have been hired to do).
Remove and replace. The bowing post cannot possibly get any better on it's own, and its effects on the slab are showing. With the wild weather this year, no one will question your call.
Pete Campbell
pete4545@comcast.net
http://www.PortStLucieInspections.com
http://www.ChooseGI.com
http://ifwemissitwewillfixit.com
Inspecting Fort Pierce, St. Lucie Village, Lakewood Park, Vero Beach, Indian River Shores, Sebastian, Fellsmere, Fort Drum, Okeechobee, Jensen Beach, Stuart, Palm City, Hobe Sound and Indiantown, Florida.
Old 9/22/11, 8:45 AM
Robert J. OConnor's Avatar
That column is unstable and needs to be replaced. And because it is already bowed, it could completely fail very suddenly.
Columns fail by buckling, and anytime the load is outside the middle third of the column it's considered unstable. That one is out of plumb by way more than 1/3 the width. The bowing also creates eccentric loading on the column which increases the stresses and the likelihood of failure.
JMO & 2-Nickels ...
Robert O'Connor, PE
LIU CW Post Adjunct Professor
NACHI Education Committee
www.reporthost.com/-rjo
Old 9/22/11, 9:05 AM
Joe Funderburk, CMI's Avatar
Was there a footing beneath the columns? I carry a 2' long screw driver and probe areas like that. Probably not based on the cracking I saw. Warped column is a structural issue.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Another way to support a house dvalley Exterior Inspections 3 10/30/09 3:45 PM
Where do I put the Aquarium? mcyr Structural Inspections 3 11/6/07 3:05 PM
