Old 2/14/07, 12:29 PM
apolillo's Avatar
apolillo apolillo is offline
Please Note: apolillo is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Web I-Joists
Fellow Inspectors,
Exterior wall, new construction. There are two sets of joists, the one on the outside seems to be continous. The interior ones are cut and not bearing fully on the top plate. One, not pictured at the end shows deflection / damage in the web.
The office was closed, so I could not see the plans. I wrote it up, but would like some more information for my client.
Thanks,
Anatol
web-joists-dsc00646.jpg   web-joists-dsc00647.jpg   web-joists-dsc00648.jpg   web-joists-dsc00649.jpg   web-joists-dsc00650.jpg
Old 2/14/07, 1:15 PM
Default Re: Web I-Joists
Looks like they are using scrap pieces of I-Joists for ceiling nailers. The continuously bearing one is on the outside of the wall, I believe.
The non-pictured damaged web is another item.
Larry Kage, CMI
231 929 3525
Old 2/14/07, 1:39 PM
apolillo's Avatar
The damaged web is on one of these, so as along as the flange is ok, it should be fine as a nailer for the ceiling.
Thanks, Anatol
Old 2/15/07, 7:46 PM
Thanks, Anatol
Anatol;
Larry is correct in saying what he said as far as using left over or cut outs used for nailing purposes for the ceiling nailers.
The problem I see now is the fact you will never be able to install insulation around the perimeter of the rim joist. Considering the State, it would be recommended.
Another point would be the fact that they did not use a rim joist Manufactured by the TJI Product. They used a TJI. That creates another void on the exterior.
Just not a standard building practice.
JMO
Marcel
Old 2/15/07, 11:14 PM
apolillo's Avatar
Good point, Thanks
floor joists Kyra Bloom Interior Inspections 19 11/23/07 10:38 AM
Where do I put the Aquarium? mcyr Structural Inspections 3 11/6/07 3:05 PM
What's Wring With This Picture: Bored Holes in Floor Joists? homebild Structural Inspections 17 5/4/07 8:33 AM
Ceiling discoloration from joists? dtaylor General Inspection Discussion 4 8/3/06 12:27 AM
Cantilevered Joists Steven Brewster Structural Inspections 13 5/9/06 7:32 PM
