Old 6/22/08, 12:40 PM
mnicholet's Avatar
mnicholet mnicholet is offline
Please Note: mnicholet is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default wedge supporting rim joist
What do you think of these pics? It appears as the foundation wasnt formed high enough for the floor joists to be level when the foundation stepped up. So, in the pics there is a sill plate, wedge(s) another 2x4 and then the rim joist. This is a new home. Thanks.
ID:	22138   wedge-supporting-rim-joist-vancouver-120-small-.jpg.jpg
ID:	22139   wedge-supporting-rim-joist-vancouver-121-small-.jpg.jpg
ID:	22140   wedge-supporting-rim-joist-vancouver-140-small-.jpg.jpg
Old 6/22/08, 10:14 PM
rshuey rshuey is offline
Please Note: rshuey is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: wedge supporting rim joist
I have never in my life seen an "engineered floor system" built like that. If there is need for a STEEL shim now and agin, ok. But that is horrid. No matter how and at what rating the beam was designed, those 2 x 4's just became the weakest link.
Scary.
Old 6/23/08, 10:00 AM
Unmoderated Guest
What wedges in can easily wedge back out again...unless the wedges are nailed, but still...if it were a project of mine, I would demand solid blocking, not wedges.
Old 6/23/08, 11:35 AM
David P. Valley's Avatar
It would have been much easier to simply add rods and then install forms to the existing foundation and pour additional inches of concrete
Was the builder smoking the good stuff?
Old 6/23/08, 12:01 PM
Can't tell from the photos... what Richard said, but if it's only a short distance I wouldn't call it a defect likely to lead to early failure. I'd call it out as poor quality construction and mention that this situation usually calls for solid shims- an additional 2x plate plus/or layers of plywood of proper thickness.
If it did lead to failure, how would it fail? I only see one wedge and even if it fell out, there's a rim joist on edge resting on the sill plate. Loss of the wedge wouldn't really cause a problem.
Ugly though. Not executed in a workman-like manner.
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Max load allowed on 2x2 ledger bking Structural Inspections 4 12/23/07 2:05 PM
Where do I put the Aquarium? mcyr Structural Inspections 3 11/6/07 3:05 PM
Joist Hangers at Cantilevered Rim pdickerson Exterior Inspections 21 8/18/07 6:19 PM
Frost, Ice, & Condensation @ RIM JOIST Sean M. Jeric Inspecting HVAC Systems 4 2/5/07 6:56 PM
