Old 6/1/07, 12:04 PM
alassiter alassiter is offline
Default Wet Crawl Space
I am in the Hampton Roads area of Virginia. I have seen several crawl spaces that have had water in them. I am going by the silt left on the Vapor Barrier. When is a good idea to blow sand into a crawl space? I have heard some different thoughts from older Realtors.
Thanks A. Lassiter
Old 6/1/07, 1:53 PM
ekartal6 ekartal6 is offline
Please Note: ekartal6 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Wet Crawl Space
High water table in area? Drainage issues? The problem needs to be identified and corrected instead of absorbing it..
Old 6/1/07, 9:03 PM
Marc D. Shunk's Avatar
Banned
Never, unless you're the dishonest sort that tries to cover up problems.
Return air from crawl space WHI Inspecting HVAC Systems 11 1/9/12 7:43 PM
Gas flex line in crawl space Richard Seay Plumbing Inspections 19 8/12/08 8:12 PM
Crawl space in under house dnasser Structural Inspections 15 2/27/07 7:12 PM
Manufactured home crawl space sstanczyk Structural Inspections 2 2/19/06 4:23 PM
