Old 3/13/06, 10:53 PM
Joe Funderburk, CMI's Avatar
Default What's the point of these piers?
As far as I can tell, these piers (pier and curtain wall construction) do nothing. One entire side of the house was like this. Seems that the wall, not the piers, is doing all the work.
Comments or advice on how to report? House is < 10 years old.
whats-point-these-piers-030906-188.jpg whats-point-these-piers-030906-189.jpg whats-point-these-piers-030906-190.jpg
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 3/13/06, 11:24 PM
Jay Moge's Avatar
Jay Moge Jay Moge is offline
Default Re: What's the point of these piers?
looks like the blocks heald the house up while the masons did nicey nice with the bricks, and just kept them as added suport. i like a base thicker than a brick to hold up my house too. was there anything else ie; piers, lalycolumns, or what not???
Old 3/13/06, 11:30 PM
Elsewhere there were central piers under beams. The other walls had similar piers supporting band sills/rim joists. The supports at this wall seemed not quite right to me.
Theodore Roosevelt
Joe Funderburk, CMI
Old 3/13/06, 11:32 PM
Jay Moge's Avatar
i see your point, the sill plate isn't even on the blocks ( i missed that the first time). i still think it's just support, maybe for the brick not the house, so it doesn't deflect? like a backbone of sorts.
Old 3/14/06, 2:56 AM
jclark1's Avatar
jclark1 jclark1 is offline
Please Note: jclark1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Are they some kind of reinforcing pilasters for the wall?
Old 3/14/06, 4:51 AM
Shawn Rowe's Avatar
Shawn Rowe Shawn Rowe is offline
That is what I was wondering...is there a high grade or back fill on the other side of that wall?
Old 3/14/06, 7:36 AM
Yes, they look like pilasters that help hold back horizontal forces from the exterior.
Old 3/14/06, 8:13 AM
rwand1 rwand1 is offline
I vote for pilasters.
Old 3/14/06, 9:47 AM
Russel Ray's Avatar
I usually vote for people or I vote in NACHI polls.
Since neither of them are present here, Miss Margarita and I will go along with pilasters.
Old 3/14/06, 3:20 PM
dhelm's Avatar
dhelm dhelm is offline
I believe Mr. Clark was the first with the right answer
Old 3/14/06, 4:50 PM
ckratzer ckratzer is offline
Please Note: ckratzer is a non-member guest and is in no way affiliated with InterNACHI or its members.
I too believe they are "support pilasters".
I've not seen them used in brick foundations but I do use the same technique, (with poured foundation walls),on homes I build that have particularly long walls.They work quite well in preventing possible cracks from backfill pressure.
Old 3/14/06, 4:54 PM
tneumann's Avatar
tneumann tneumann is offline
Sorta like a "deadman" on the retaining walls I have built in the past.....
Old 3/14/06, 5:13 PM
Exactly.
"Deadmen" is what we call them around here too.
Old 3/14/06, 7:26 PM
Exactly what they are; Pilasters, and usually they are reinforced with some re-bar to help the wall in later stability.
I could be related to the flying buttresses of Ancient Rome Architecture. Downsized over the years and inverted from outside to inside. ha. ha.
Marcel
</IMG></IMG>
Old 3/16/06, 10:52 AM
Pilaster definition: "a rectangular column that usually projects about a third of its width from the wall to which it is attached." I suppose this type of column is commonly called a pilaster, but these definitely do not project 1/3 from the wall. The crawl space wall is one course of brick thick--the column projects about 85% from the wall.
Most of the time, similar "pilasters" that I see actually support the load of the structure. This is not common in the Carolinas and I'm thinking it doesn't do a thing.
There is no soil on the outside of the wall that would require the use of a "backbone". The entire crawl space is above grade.
Theodore Roosevelt
Joe Funderburk, CMI
Helical Piers vs Push Piers rnewland Structural Inspections 23 12/3/07 8:50 PM
Proposed Definition of Neutral Conductor and Point jtedesco1 Electrical Inspections 1 4/22/06 10:19 AM
