ccbrands1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
I've seen these in a few homes, but not sure 100% what they're for.
There were 2 in this attic, bot running perpendicular the the joists. |
Hi to all,
these just appear to be the tops of non-load bearing walls, I used to see a lot of this in older properties up in New England. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
thanks, gerry
When I was about 16 (oh,-- maybe 10 years ago) I noticed a builder include walls like that. They were open to the crawspace and he said he used them to install wiring or pipes or vents later if the homeowner wanted something added. (This was a very small towm and he was the only builder there.)
jschulte is a non-member guest and is in no way affiliated with InterNACHI or its members.
You can find some of those in my attic. When my house was built in the 1860s, I imagine it was quite common. But it was not put in for easy plumbing or wiring, as there was no plumbing or wiring to be concerned with in this area. Everything was outdoors and oil lamps. I magine it was just easier to frame.
rrichards2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
This is common on old balloon type house framing. This type of construction was replaced with platform framing. Houses don't go up in flames quite as fast now.
| VIDEO--Bowed Basement Wall, Cracks etc | john bubber | Structural Inspections | 75 | 7/21/08 6:25 PM |
| Where do I put the Aquarium? | mcyr | Structural Inspections | 3 | 11/6/07 4:05 PM |
| egress window well retaining wall | Ivor Findlay | Structural Inspections | 4 | 5/23/07 11:03 AM |
| Newbie here with a slab "standards" question | Robert Young, #3 | Structural Inspections | 17 | 4/10/07 11:48 AM |
| No Brick Ties - Wall Buldge | Stew | Structural Inspections | 1 | 4/22/06 7:56 AM |
