Home is 15 years old. Note the new vapor barrier lapped and taped 2' up all the walls and piers. Insulation was new also. This is NOT a conditioned crawl space.
(1st time for me seeing this type of coating on floor joists. Thought others may learn from it. I'll tell you what I said about it later.)
| Find an InterNACHI certified Iowa Home Inspector (and anywhere else in North America) |
Sure beats what I see when I get them.
Hey Joe
Out here they paint joists white or gray after a fire to seal the smoke smell. Did you see any evidince of charing or burn areas. Or smoke staining on any other areas. Possible cause Might be becuase of the extension cords there in the pic. LOL House 2 Home LLC 503-602-1420 HomePros@House2HomeLLC.ORG Protecting Peace of Mind One House at a Time IAC2 Certified IR Certified A favorite place on Google Maps |
Not a fire.
gmelien is a non-member guest and is in no way affiliated with InterNACHI or its members.
Let's see, evidence of new vapour barrier on floor, painted joists, new insulation, and painted joists, I say it was probably MOLD!
Mold blocking paint/sealer used after remediation.
The mold remediation companies around here typically paint treated surfaces after CO2 or soda blasting them with a calcium carbonate based paint. I would see if there was ever any issues with mold in the past. They also use a white paint like Kilz or Zizbar after fire restoration work, but you aready said there wasn't a fire.
Scott Gilligan 215-888-4943 Infraspection Institute Level III Certified Thermographer Philadelphia Mold Inspections Philadelphia Home Inspections Philadelphia Commercial Inspections Philadelphia Licensed Home Inspector Pennsylvania - New Jersey - Delaware Infrared Thermal Imaging Inspections President The Greater Philadelphia Chapter of InterNACHI http://pa.nachi.org/greaterphiladelphia Vice President & Webmaster National Association of Commercial Building Inspectors and Thermographers |
I would say MOLD !!!
Mid America Property Inspections, Inc. Shawnee, KS 66217 www.mapii.com NACHI # 05110992 KHIRB # 0110-0008 KS-Radon Cert.# KS-MS-0035 KS-Termite Cert. # 18933 M0-Termite Cert. # N 5033 |
Why only 3" of the bottom? I was going to say intumescent paint but the job is not done properly.
LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
MOLD is my guess also, especially since the lot grade sloped toward the house on 2 different sides and since the crawl space vents were at grade level in places.
![]() "The floor joists have been coated with a substance we suspect is an anti-microbial compound, which is consistent with previous work by a mold remediation company. We suggest that you ask for full disclosure by the current owner as to the nature, purpose and scope of the work and obtain copies of any guarantees, permits, etc. related to this activity. Note that mold growth is symptomatic of high moisture conditions. Any remediation should have taken moisture control into consideration to prevent recurrence of fungi growth. More information about mold can be obtained on our website. (Note also that the sub-floor insulation in the crawl space appeared new, also consistent with mold remediation.) The vapor barrier in the crawl space appeared new and it was unusual in that it lapped 2 feet up all perimeter walls and piers. We suggest that you ask for full disclosure by the current owner as to the nature, purpose and scope of the work related to this activity. Our experience is that vapor barriers may conceal but not correct a larger problem related to water intrusion in the crawl space." “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
Well shucks I thought it was whitewash. I wonder why nobody ever uses whitewash anymore.
Mold remediation contractors use it all the time after CO2 (dry ice) or Soda (sodium bicabonate aka baking soda) blasting. Scott Gilligan 215-888-4943 Infraspection Institute Level III Certified Thermographer Philadelphia Mold Inspections Philadelphia Home Inspections Philadelphia Commercial Inspections Philadelphia Licensed Home Inspector Pennsylvania - New Jersey - Delaware Infrared Thermal Imaging Inspections President The Greater Philadelphia Chapter of InterNACHI http://pa.nachi.org/greaterphiladelphia Vice President & Webmaster National Association of Commercial Building Inspectors and Thermographers |
LOL i know so why not call it White wash .
| When Chocolate City | klott | Miscellaneous Discussion for Inspectors | 28 | 6/23/08 8:12 AM |
