Old 10/1/11, 8:14 PM
Linas Dapkus's Avatar
Linas Dapkus Linas Dapkus is offline
Default Why Is This Building Leaking?
I had a 3 unit condo building a few days ago that had some "issues". What's wrong here??
Need a home inspection in Ohio? Check out InterNACHI's listing of Ohio certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/1/11, 8:30 PM
Dale Duffy's Avatar
Default Re: Why Is This Building Leaking?
Nice-----
What do they consider FLASHING, the six-mil----
Incredible----
Old 10/1/11, 8:41 PM
Originally Posted by dduffy View Post
Nice-----
Incredible----
The insulation absorbs the water that soaks through the block. When you see mold growing on the walls, you remove the drywall, wring out the insulation and replace the drywall. Pretty simple, no?
Old 10/1/11, 8:48 PM
Dale Duffy's Avatar
Yes, Yes, that's what I would recommend as well, nice Job Linas---
Once the insulation is wrung-out, she's ready for another stellar installation--
Old 10/1/11, 9:20 PM
Jeffrey Moore Jeffrey Moore is offline
Dang Linas,
I think some of our construction guys moved to your neighborhood
Jeff Moore
www.quantumhomeinspections.com
Flir (ITC) Level II Thermographer
Mesa, AZ
Old 10/1/11, 9:27 PM
Originally Posted by jmoore5 View Post
Dang Linas,
This contractor was from Poland, your construction guys come from just south of the border.
Old 10/2/11, 8:30 AM
Sean Fogarty's Avatar
Was that the split block you guys keep squealing about on that building?
I would think the plastic could help divert the water into the neighbor below. Must be a B-Dry system.
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Old 10/2/11, 9:12 AM
Yes, it's split face block. See anything wrong with this? Is the poly behind the drywall OK? Do they need more insulation or is R-3 OK? How about a drainage plane? Framing nailed to block is OK? please help!!
Old 10/9/11, 9:04 AM
Mark S. Tyson Mark S. Tyson is offline
Maybe they put the required R-13 under the slab with the vapor retarder and then used the vapor barrier on the walls. Will you be testifying as part of the upcoming class action lawsuit. I'll leave the window installation deficiencies for another day
Mark S. Tyson
M Tyson construction LLC
Tyson Home Inspections
Certified General Contractor #1516843
Florida Licensed Home Inspector #1824
Member N.A.C.H.I.
IAC2 certified
Member Florida Building Officials Association
http://www.TysonHomeInspections.com
I Can't Believe HomeGauge is charging $200/year for what was a free mkyriacou Inspection Hardware, Software & Publications 88 7/9/10 2:13 PM
Woman Sues County for Not Enforcing building Codes jbushart Legislation, Licensing & Legal Issues for Inspectors 4 4/1/09 8:09 AM
No "H" clips? jbreazeale Structural Inspections 7 5/17/07 2:28 PM
