Why we should get into crawlspaces.
Just found this yesterday. This was in a ten year old house just below the master bathroom toilet.
What you are seeing is the bottom side of cement board and the bottom of the actual toilet. There is about a 1.5" gap between the toilet and the toilet flange. What is really amazing is that when I had the client flush the toilet two or three times not one drop of water came out. The third photo is the toilet in the master bedroom above. Not much evidence, even the toilet was tight to the floor because of the caulking around it. The reason the toilet and someone sitting on it didn’t end up in the crawlspace was because the front and rear of the toilet are supported by the joists below.
I couldn’t confirm it but it looked as if there may have been no wax ring installed. The diameter of the damage is about 5 feet and it extends below the bathroom sink, the whirlpool tub and a wall which is shared with the master bedroom. This one is going to cost somebody a lot of money.
Good find. Structural defect and just a matter of time before mold started growing, if it wasn’t already.
Probably 3/4ths of the homes I do here in NC are crawlspace of which the last half dozen have been less than 18" with some being 12" with trenches dug in order to get around…of course they are filled cob webs, spiders, sometimes snakes, often dead rodents including a dead cat or squirrel here or there.
And of course the areas where you could probably get to but don’t want…is where the defects typically are.
One thing I always do when going into a crawlspace is to turn all plumbing fixtures on for about 10 minutes before I go into them and let them run while I am in there…this should especially be done with older homes with cast iron and galvanized piping.
Good find.
Thats the reason you should not caulk the toilet to the floor, if all that caulk was not there the leak may have been noticed on the floor and saved some of that structure
You leave the back side uncaulked. Or you sit down to piss. :smiley:
I think mold may have started to grow already Chris. :stuck_out_tongue:
Guess I should have looked a little closer huh. :slight_smile:
