Old 8/5/08, 1:44 PM
rborders rborders is offline
Please Note: rborders is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Window Well Drain Depth?
Is there a standard for depth of the drain below the frame?
Old 8/5/08, 7:39 PM
Default Re: Window Well Drain Depth?
Typical for my area is 8" (or more) below the bottom of the rough opening of the window. Typical clear depth includes an aggregate (gravel) material of at least 4" in depth.
The width is typically 4"+, of either side of the window rough opening, and this extended depth from the foundation out of at least 12", although it is recommended greater. Hope this helps.
Need help flashing top of replacement window on brick wall !!! Bill Featherstone Exterior Inspections 5 6/26/10 10:25 PM
Site grading and drainage wdevries Canadian Inspectors 5 10/6/09 10:23 PM
CPA of Health Canada reminding us of corded window coverings. gromicko Canadian Inspectors 7 4/23/07 7:31 AM
French drain tied into main drain rwashington Plumbing Inspections 6 2/16/07 11:04 PM
