Floor joists are 12" wood I-joist, I know the manufacturer installs knock-outs for running tubing etc. The plumber drilled 2-1/2" to 3" holes about 1 foot from the carrying beam end and top of beam center. Does anybody know if this creates a structural concern or not?
Sorry, I don't have any pictures of it. Thanks Scott Falvey Clear View Home Inspections, LLC Newbury, NH NACHI#05051292 www.clearviewhomeinspectionsllc.com |
go to manufactuers web site for the joists, they always show an allowable cut / hole drilling diagram or instructions. Normaly new or larger holes are allowed near the ends or within a few feet of the end.
I've seen them as big as 6". Sounds OK here. That is the great thing about I-joists.
I think you've got it backwards. The maximum shear stress occurs at the ends (support) so the further away from the end, the larger the allowed hole. |
I think Larry's posted link explains everything here, I believe. http://www.ilevel.com/literature/TJ-9001.pdf Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Doesn't the table indicate that the further away from the support, the larger the allowed hole. Am I reading it incorrectly? |
Dependant of the series and Manufacturer, that is what it looks like.
gmortensen is a non-member guest and is in no way affiliated with InterNACHI or its members.
Great thread. Thanks guys.
| Can someone explain why wood in contact with concrete causes rot? | gromicko | Miscellaneous Discussion for Inspectors | 46 | 1/16/11 11:15 PM |
| Where do I put the Aquarium? | mcyr | Structural Inspections | 3 | 11/6/07 3:05 PM |
| Tech Links Page | bkelly2 | Structural Inspections | 3 | 1/11/07 4:18 PM |
