Old 3/9/10, 7:20 PM
John Evans John Evans is offline
Default Worst Attic & Rafter Support Question
Attic was a disaster, electrical, HVAC, etc. I believe the vertical "supports" shown would be considered kneewall bracing. Correct? Check out the metal studs placed for support!
[Maryland Home Inspections
www.aimhomeinspection.com
Infraspection Certified Level 1 No. 7801
Need a home inspection in Delaware? Check out InterNACHI's listing of Delaware certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/9/10, 8:46 PM
Joshua L. Frederick Joshua L. Frederick is online now
Default Re: Worst Attic & Rafter Support Question
At least it's insulated well
Old 3/10/10, 12:53 AM
Matthew K. Klein's Avatar
Matthew K. Klein Matthew K. Klein is offline
The verticals are not necessary for a knee wall. There is a type of construction where the home has a middle hallway with rooms on each side. Vertical braces run from the joists on top of the walls to a girder installed under the rafters, sort of like the first photo. The girder is intended to provide a mid-span support for the rafters. Usually, these constructions have relatively long and low-angle rafter spans. This construction is adaptable to a knee wall, although the headroom is not enough to provide livable space--just storage space.
However, the construction in the photos, if as I describe here, is pretty inferior--and a bit scary.
Matthew Klein, P.E., M.B.A.
Criterium Engineers
PO Box 181503
Cincinnati, OH 45018-1503
Phone: 513-474-9600
FAX: 888-747-0427
E-mail: Criterium-Cincinnati@fuse.net
Website: www.Criterium-Cincinnati.com
Roof decking condensation. Homewood Interior Inspections 15 3/5/10 12:00 PM
Attic question wsiegel Structural Inspections 8 1/18/07 11:08 AM
Home Warranty Attic Insulation Question jhawes Canadian Inspectors 2 12/4/06 2:54 AM
Attic ventilation question pdoane Interior Inspections 8 8/27/06 3:22 PM
