Noticed the driveway was really offset at all the sections. Vertical and horizontal crack at master bed, vertical crack above master bed door, up bed door sticks at frame, fireplace movement due to the caulking separating on both sides, and the chimney outside has a fairly good sized separation that has been caulked. One other bed wall has a vertical crack that has been patched before and now has reappeared.
Richard W. Washington, owner RW Home Inspections, Inc. www.RWHOMEINSPECTIONS.com Texas Real Estate Commission (TREC) Professional Inspector License #7238 Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter InterNACHI member since 2004 Based in Katy, serving Houston and all surrounding communities |
| Find an InterNACHI certified Montana Home Inspector (and anywhere else in North America) |
more pics
The sideways pictures (first pics in both secquences) make me dizzy and I don't see what you must see. The other interior pictures where I can see the drywall cracks, they look typical and minimal to me.
The driveway slab has settled, substantial cracking and has heaved. But I don't see where one might call for "foundation" repair (which I consider footers, CMUs, etc). InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
You should have used a 6' level on the inspection to support any claim to chimney, walls and floor having settling issues (with photos). With this data then you could recommend a structural engineer to further examine foundation. Cracks can occur just from shrinkage of framing materials and other issues not related to the foundation.
"Inspected Once, Inspected Right" ![]() |
I'm used to seeing diagonal cracks off the corners of wall openings when there's been foundation movement. When I see vertical and horizontal cracking it's often cracks following joints in drywall.
Those walls looked like plaster. Were they? Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
Did the neighbors driveways look the same?
Find any cracking on the exterior foundation, interior floors? What age is the house? Any cracking in brickwork on those exterior walls?, around windows or doors? |
If its a foundation issue then you need to be showing us some pictures of the foundation itself including around the footer...........otherwise its nothing more than unfounded speculation based upon some sideway pictures which make my neck hurt.
Driveways can crack yet the foundation is fine........one has to becareful about tying the two together without seeing cracks and displacement within the foundation itself. regards Jeff |
Yep. Soil movement may be from heaving due to expansive soil or frost heave, in which case it may continue; or it may be consolidation due to poor compaction at the time of original construction, in which case it's often stable.
Nope. Defer it to a trade professional and put the turd in their pocket.
Could you be more specific?
rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
I can see that the walls need repair and the driveway has settled, but cannot comment on the foundation in this limited visual inspection. |
The step crack is not normal. However still to many questions. What condition was the foundation in? Are there any rooms upstairs where the step crack is? If not did you go look in the attic to see what might be up there?
Bill Boerner STL Home Inspection ServicesServing St. Louis/Surrounding (314) 805-2137 billy.boerner@gmail.com http://www.stlhomeinspector.com |
Richard
From the pictures it appears site grading and poor water runoff management is putting excessive amounts of water next to the foundation. The uneven drive is a classic example of subgrade failure due to excessive moisture. To make matter worse the one photo looks as if the drive is now sloping towards the house. As a home inspector I would note cracks and possible settlement and suggest further investigation needed. As a Structural Engineers my advice would be first develop a plan to manage the grading and runoff issues then second depending upon the foundation type and the severity of the settlement look at mudjacking and/or screw anchor jacks to restore the foundation to the proper elevation. This is the short version, there are more measurements and cost estimates that need to be done to verify my assessment and to determine the most economical solution for this homeowner. |
| Electrical Inzpections | jtedesco1 | Electrical Inspections | 9 | 9/14/08 10:14 AM |
| San Francisco Appliance, Air Conditioning and Heating Repair | Ron Casey | General Inspection Discussion | 0 | 5/11/08 2:48 PM |
| Nice Report on AL Wire Terminations - Enjoy | pabernathy | Electrical Inspections | 0 | 7/2/07 1:35 PM |
