The attached picture is of a roof truss system installed in the Wind Borne Derbies Zone (130mph) of SE Florida. Do you see any problems? Forget the radiant barrier
Mark S. Tyson M Tyson construction LLC Tyson Home Inspections Certified General Contractor #1516843 Florida Licensed Home Inspector #1824 Member N.A.C.H.I. IAC2 certified Member Florida Building Officials Association http://www.TysonHomeInspections.com |
| Need a home inspection in Delaware? Check out InterNACHI's listing of Delaware certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Mark, that is a very confusing picture.
It looks like a truss with a piggy back truss on it and then sistered with what looks like a 2x8 common rafter. What are we looking at? LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I must agree with Marcel. The ridge board is covered with foil I would suspect. Not sure if this is a good idea according to no heat dissipation at the ridge.
Truss plate is not the size needed for 2x8 common rafter. THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 Last edited by kwood; 11/5/11 at 7:39 PM.. |
Page 10 shows the installation of the Piggyback truss.
http://search.yahoo.com/r/_ylt=A0oGd...odtech-104.pdf And Mark, still confused as to what looks like a sister next to those trusses. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I don't know if you notice this Marcel but I think the one he has on this thread is on page 3.
THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
I was pointing out the proper recommended one.
I got that message!
We will have to wait on this one until Mark comes back. Remember we all have an extra hour tonight. THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
I realize the picture is kind of crappy but if you look at the trusses in the background you can see the required plywood gussets. As a general industry standard in this neck of the woods plywood gussets on both faces two feet o.c. with 4 nails top and bottom Mark S. Tyson M Tyson construction LLC Tyson Home Inspections Certified General Contractor #1516843 Florida Licensed Home Inspector #1824 Member N.A.C.H.I. IAC2 certified Member Florida Building Officials Association http://www.TysonHomeInspections.com |
Thanks for that info. So the truss plate is too small but makes no bearing on this piggy back because of the tie in with plywood gussets. It was hard to see but after blowing it up to full size you can see them in the back ground and not in the for ground. Good call on that one.
| Free Books And Articles For Electrical | jtedesco1 | Electrical Inspections | 14 | 1/6/08 6:45 PM |
