| View Poll Results: How would you report the chimney in the photos | |||
| Monitor |
3 | 5.77% |
| Structure engineer |
40 | 76.92% |
| Satisfactory |
7 | 13.46% |
| Chimney sweep |
2 | 3.85% |
| Voters: 52. You may not vote on this poll | |||
Explain why.
Here is an additional photo.
What did the footing look like for the chimney, I would definitely call this out. The separation just from the point of the photos is rather scary,. What did this look like from the inside? A call out at minimum for a qualified masonry contractor or Structural PE.
Joe Kormos A-1st Look Home Inspectors Inc. 630-201-0933 Your 1st Choice in Property Inspection Professionals www.a-1stlookhomeinspectors.com www.a-1stlook.com Let us look before you buy...for peace of mind “Thinking is the hardest work there is, that’s why so few engage in it. ” Henry Ford |
The added picture is not the one in the post. I had to make sure this was no longer in use. As you can see it doesnt vent to the outside. What are the requirements when an exterior chimney is used for the HVAC/Tank? Does it have to have a liner? Last edited by dmacy; 5/11/07 at 2:39 PM.. |
If it was for an FP you could look up the flue, but since it is for HVAC, a flue liner would help. But first it will need to be determined as to why it is pulling away from the building, if that were to collapse, not to be an alarmist, it could kill someone if it were to fall.
Dave Morris is a non-member guest and is in no way affiliated with InterNACHI or its members.
you would be asking for it if you didnt call it out. It may have been this way for 30 years but that isnt for us to decide. at any rate, I wouldnt want the gap between the house and chimney even if it fine structurally.
afrost is a non-member guest and is in no way affiliated with InterNACHI or its members.
are those brick ties in photo #2? if so, it looks like the ties stayed fastened to the house and slid out from the masonry!
call it out. the masonry should have been tied back to the wood studs with metal brick ties. movement is unacceptable. (fix might include tear down and rebuild) hardhat area. |
Be careful reporting "chimney pulled away from house" unless you are sure that it is not the house that moved.
Especially on log homes, the most frequent cause is that the house pulls away from the chimney as the logs dry out. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Further review needed.
Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
homebild is a non-member guest and is in no way affiliated with InterNACHI or its members.
Building codes require that masonry chimneys be constructed with at least a 1-2" clearance to combustible materials. Clapboard siding is a combustible material and the clearance from the chimney to its surface is mandatory.
R1001.15 of the 2003 International Residential Code and R1003.18 of the 2006 International Residential Code both state: Quote:
Seems to me that the chimney is constructed properly and that the 'gap' to the structure is intentional and required to be there. Nothing wrong with the chimney. I voted 'satisfactory'. Last edited by homebild; 4/24/07 at 8:28 AM.. |
the soffit should also have the 1" space.
the gap needs to be closed, tho. i'm unsure how that is typically done. Last edited by afrost; 4/24/07 at 10:05 AM.. |
If the gap were larger at the top than at the bottom, or if the chimney itself were not perfectly straight, I would be concerned. If the chimney is tied to the house at certain intervals, then I see nothing wrong with it as shown. One might want to close the gap for cosmetic reasons, and there are several ways to do that...wood trim, metal angles, etc.
trim is allowed to cover gap
lewens is a non-member guest and is in no way affiliated with InterNACHI or its members.
Larry |
Simple answer: You can't. But since this case study occurs in Ohio, and since Ohio utilizes the International Residential Codes, it's a pretty safe bet there has been some code oversight over the construction of this chimney even if that oversight was under the obsolete BOCA codes. Irrespective of 'Code', however, what is captured in the initial photos iabove is very 'normal' and a standard practice for masonry chimney construction anywhere. Clearances need to be maintained to combustible surfaces from masonry chimneys as shown in the photos no matter what the local 'code' requires and regardless of jurisdication. Masonry chimneys should also be anchored to the structure every so many feet vertically to stabilize them. More anchorage in active seismic zones. Bottom line: There is absolutely NOTHING "wrong" or "unusual" about the construction of this chimney apart from what the codes say. What appears is common, safe, and normal masonry chimney construction practice. Last edited by homebild; 4/24/07 at 7:37 PM.. |
| Artist or Incompetent, You make the call. | bkelly2 | Plumbing Inspections | 21 | 3/18/06 6:18 AM |
| Call centers | jcordell | General Inspection Discussion | 13 | 1/25/06 11:12 AM |
| Cell phone "do not call registry" | sspradling | Miscellaneous Discussion for Inspectors | 2 | 1/11/06 5:35 PM |
