In a plumbing drain system: Its permissible to transition from ABS to PVC how many times in a single run?
One time
One time only… in the entire residential home.
As many as needed using listed mechanical connectors with elastomeric seals
only one transition fitting is permitted with the appropriate transition solvent
Several correct, Mike was first.
You can also do as many as you want using threaded connections…
