| Inspection Education & Training This is a general forum for inspectors to discuss their educational experience, and to ask questions of InterNACHI's Education Committee. This forum is dedicated to the memory of InterNACHI member and educator Gerry Beaumont. Gerry was an avid proponent of education for inspectors and will be sorely missed. |
| Find an InterNACHI certified Idaho Home Inspector (and anywhere else in North America) |
Looks Great!
Is it just roofing so far? |
Yes, we hired 2 graphics artists and they can only produce about 6 or so images per day. Each day we will add more.
Should be of great benefit to many.
Good stuff! Thanks Nick.
http://www.SmithHomeInspection.com SmithHomeInspection@yahoo.com NY State Lic. # 16000008304 631-434-5200 |
Good stuff!
Hey Nick,
Would it be possible to make the entire library available for download? I don't have Internet access on site, and would like to have the library available for reports or even for showing a client. Downloading them individually would be very time consuming, also it would be difficult to remain current (where periodic re-downloads) would be relatively easy. (Maybe a monthly, quarterly, bi-annual, or even annual versions?) I could also see that as being a viable product you could sell to non-members and publishers. Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
We are adding so many every day. I'll make CDs available when we get to 1,000 images (probably next month). OK?
www.nachi.org/gallery Nick Gromicko, Certified Master Inspector Find a Home Inspector "Just as iron sharpens iron, one man sharpens another." Proverbs 27:17 |
Nick...the image in the electrical folder showing the NM Cable running through studs is incorrect. While if the cable is run less than 1 1/4" from the edge of the stud you are required to install a nailplate the other ones shows a hole with a compliantly drilled stud but it says it needs to be 1 1/2" from the edge....it should both reflect the 1 1/4" statement.
Plus the reality is it has the same requirements if it is interior or exterior side of the stud....siding people drive nails through studs all day long as well. (1) Bored Holes. In both exposed and concealed locations, where a cable- or raceway-type wiring method is installed through bored holes in joists, rafters, or wood members, holes shall be bored so that the edge of the hole is not less than 32 mm (11.4 in.) from the nearest edge of the wood member. Where this distance cannot be maintained, the cable or raceway shall be protected from penetration by screws or nails by a steel plate(s) or bushing(s), at least 1.6 mm (1.16 in.) thick, and of appropriate length and width installed to cover the area of the wiring. Remember...it says nothing about Interior portions only........something people really need to be aware of as many see the tree's but overlook the forest in the process. Always send me your images fella first....I dont mind proofing them as time permits...
Paul W. Abernathy Last edited by pabernathy; 7/18/09 at 12:33 PM.. |
| InterNACHI's new library of self-study graphics. Advanced training. | gromicko | Miscellaneous Discussion for Inspectors | 25 | 5/18/09 5:00 PM |
| Advanced commercial inspection graphics library. Coming soon. | gromicko | Commercial Inspections | 1 | 4/4/09 2:41 AM |
| Dot "me" domain extension opened up for registration today on GoDaddy.com | gromicko | Miscellaneous Discussion for Inspectors | 11 | 7/27/08 7:02 AM |
| Today we opened up this forum to non-members. | gromicko | General Inspection Discussion | 21 | 10/25/06 5:29 PM |
