| Inspection Education & Training This is a general forum for inspectors to discuss their educational experience, and to ask questions of InterNACHI's Education Committee. This forum is dedicated to the memory of InterNACHI member and educator Gerry Beaumont. Gerry was an avid proponent of education for inspectors and will be sorely missed. |
Hi, I have a clarification question for you guys again:
In the plumbing section, it states that the water main shutoff valve should be identified, but that caution "must be exercised with old shut-off valves, as they can easily leak when they have not been operated in some time." Does this mean that we are expected to operate the shutoff valve, or merely look at it to identify it? Most other sections of this course have indicated that we are not supposed to operate shutoffs of any sort, but instead just identify the location and condition of them. So what is the NACHI recommendation for the water main? Do I test the valve or not? Thanks! Hank |
| Need a home inspection in Georgia? Check out InterNACHI's listing of Georgia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Absolutely not.
No, do not test. Just identify and report the location of the valve.
Thanks guys. That's what I thought, but just wanted to make sure.
Another question: This one is in reference to garage doors: http://education.nachi.org/show.php?...31&course_id=1 According to the course, it says "Automatic garage doors can be problematic to inspect, and many inspectors have found themselves buying the homeowner new doors or openers as a result of improper inspection and operation. Automatic safety systems have been mandated on garage doors for more than 10 years due to injuries, particularly to children. As this is a safety concern, the doors should be evaluated for proper automatic reversing, and that photo eyes are both operable and installed according to the manufacturer's instructions." However, it then goes on to say that THE INSPECTOR IS NOT REQUIRED TO: J. verify or certify safe operation of any auto-reverse or related safety function of a garage door; So what I want to know is, why were inspectors liable to homeowners and had to buy new doors or openers if they were not supposed to verify or certify auto-reverse on the doors? Or is "J" an antiquated comment that should be removed from the list of things inspectors are not required to do? By the way, you guys are awesome. I love how fast responses come in. Thanks! |
Many inspectors confuse "not required" with "not allowed".
Nachi SOP does not require it but does not prohibit it so many inspectors check at least some of the safety items listed below. NC requires us to check the force reverse feature. Safety functions of garage doors/openers include all of these seperate features and items: 1. Safety beam operation. 2. Entrapment release test (2x4 method) Very risky test. 3. Force reverse. The system uses an optical sensor to monitor revoultions of the motor drive. Low revolutions = must be hitting something. 4. Spring(s) operation and balance check. 5. General hardware inspection. Tracks, mounts, hinged rollers, bolts. 6. Height of wall switch and safety beams above floor. 7. Manual lock disabled when auto opener installed. 8. Safety cables present through any side mount springs. 9. Door bracing present depending on door size and location of house/codes. 10. Proper warning labels present on door and next to wall switch. There are some new systems that do not require safety beams as long as the opener is certified to reverse at the correct level and the anti-pinch door is present. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Sticking an arm or a 2x4 in the path of a closing door and damaging it is not considered to be testing it under normal operating conditions and can result in damage that an inspector can expect to pay for. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 |
| Diploma mill ASHI unleashes another consumer mass murderer onto the general public. | gromicko | Legislation, Licensing & Legal Issues for Inspectors | 130 | 12/2/10 10:21 PM |
| New Hampshire State Chapter Meeting | fcarrio | Miscellaneous Discussion for Inspectors | 9 | 4/29/09 4:20 PM |
| Tennessee Licensing Requirements | hspeakman | Legislation, Licensing & Legal Issues for Inspectors | 58 | 4/23/09 11:32 PM |
| ILLINOIS Section 1410.200 Standards of Practice | jtedesco1 | Legislation, Licensing & Legal Issues for Inspectors | 11 | 3/9/06 11:22 AM |
