Go Back   InterNACHI Inspection Forum > Inspection Education Topics > Inspection Education & Training
Inspection Education & Training This is a general forum for inspectors to discuss their educational experience, and to ask questions of InterNACHI's Education Committee. This forum is dedicated to the memory of InterNACHI member and educator Gerry Beaumont. Gerry was an avid proponent of education for inspectors and will be sorely missed.
Old 4/14/11, 5:18 PM
Ben J. Gromicko's Avatar
Ben J. Gromicko Ben J. Gromicko is online now
Default “How to Perform Roof Inspections” Course
This thread is dedicated exclusively for those students currently enrolled in the InterNACHI course titled, "How to Perform Roof Inspections" located at http://www.nachi.org/roofingcoursereleased2005.htm
Thank you.
BEN GROMICKO
InterNACHI Director of Education
Now That You've Had a Home Inspection" Book
Need a home inspection in Indiana? Check out InterNACHI's listing of Indiana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 8/4/11, 1:47 PM
Robert J. Stawicki Robert J. Stawicki is offline
Default Re: “How to Perform Roof Inspections” Course
I actually just finished the video version of performing roof inspections. I was not clear on sheathing installation. Is it ok to install sheathing over barn boards and not have the ends meet at a rafter to be fastened just randomly nailing to the boards themselves?
Thanks, Bob
Old 5/23/12, 3:18 PM
David Knudson David Knudson is offline
Just my opinion;
Because barns were built with less than exact measurements, finding 16", or 24", or even 32" centers across the entire roof, could be difficult. If the underlying boards present a fairly flat plane, and are in sound condition, then screwing the plywood to them shouldn't be a problem.
However, that begs the question. If the underlying boards are sound, why the plywood? Are you about to put on a new roof material, that requires plywood underlayment, such as shingles?
If so, then look at the framing of the barn roof. It probably had steel over the boards, which were attached to some kind of rough-sawn truss. The new shingle roof will weigh considerably more. On the other hand, if the barn is old and is out of square due to wind from over the years, a layer of plywood on the roof could give the whole structure new found rigidity. Set up some instruments and assess the whole structure for level and squareness. Straighten it up and then re-enforce the roof. Re-fasten the sheathing boards to either the old/new rafters and re-sheath the roof with plywood. Then install whatever roof covering you were intending on using. Think about the fact that the structure is now more top heavy than before. Additional lateral bracing in the walls is likely required.
Lastly, I'm not Dknudson, I'm a student of his using his login and password. I have about 30 years experience as a general contractor in Canada, the US, and Central America.
Old 5/23/12, 3:31 PM
Regarding bricks;
Years ago I conversed with a brick layer in Canada. (Freezing climate). He pointed out some houses that had crystals of ice stuck to the bricks. He said this was because some types of bricks have a top and bottom. Some bricks are cut to size, and the saw blade leaves tiny striations that can either face down, to drain (correct placement) or up, in which case they collect rainwater, rather than shed it. Then, if perverse weather conditions occur, the water freezes and prematurely damages the bricks.
In your section on chimneys and bricks, you talk about 'spalling'. I think that this is the case, sometimes.
The solution obviously, is for the brick layer, to carefully choose which way is up/down, on each brick. Almost always, the bricks come on a pallet properly oriented. So, when getting them up to the scaffold, use a system that maintains that orientation.
I'm not actually dknudson, but a student using his login ID to study the course material.
Robert Pollock
alabamabob2003@yahoo.com
Last edited by dknudson; 5/23/12 at 3:37 PM.. Reason: Spelling, grammar, and identification.
Level of detail in the InterNACHI Roof Inspection Certification course/ advanced desi kshepard Roofing Inspections 5 2/13/11 2:42 PM
Cracked shingles pwigle Exterior Inspections 54 4/23/09 11:52 PM
Roof framing questions? badair Structural Inspections 7 2/22/07 7:03 AM
Moss growing on roof ecox1 Exterior Inspections 45 1/19/06 9:57 PM
